Re: audi 80 back at it!
February 16, 2014 12:12AM
Trying... however with a wife and 3 I'm rarely in charge of my own destiny lol. Idaho is for sure, and I'm trying for OTR.
February 16, 2014 12:15AM
Oh yeah and this finally followed me home
March 26, 2014 12:34AM
Finally! It freaking runs. Time for total assembly then tuning.
https://www.facebook.com/photo.php?v=10154009216775473
Test fit the 50's they are spot on travel wise I'll get some photos up as it goes together. Gonna yank the hard lines out of the car and go flexible. Kicked one this evening and kinked it and it was in a thought I'd never have believed I would get with my foot!
March 26, 2014 09:55AM
What was the slow crank? Come on! Inquiring minds wanna know!
And Hey hard lones work.. You're a savage if you crush or bend one enough to collapse or kink one..
MOAR P clips, less size 12
Robert Culbertson
Out of this dumpster fire
March 26, 2014 10:21AM
3/16 SS hard lines are very stiff compared to flex lines. If they are in an area with gravel spray, move them or shield them.
I have never seen the benefit of going to a vastly more expensive, much more flexible/spongy , and much more prone to wear brake system.
March 26, 2014 11:16AM
Robert Culbertson
I know what he's talking about though . I stumbled inside my 96 one time and stepped right on the loop of hardline looping up and going down into the handbrake master.
It was a combination of clumsiness and bad routing..
Can't cure clumsiness so gotta cure the routing
March 26, 2014 01:48PM
Starter was toast. Tested great on the bench tester too... put in the new starter and she sounds freaking awesome. just shy of 200 rpm cranking speed.
Robert, my brake lines are fine, its the fuel lines that I kicked and kinked. found a bunch of fittings and 15' of -6 line for 80 Bucks... which is like 20$ more than the hard lines and fittings cost in the first place.
March 30, 2014 11:34PM
Robert Culbertson
April 01, 2014 01:16AM
10-4 on the fittings and lines. That's a super good deal.
April 19, 2014 12:25AM
First drive (all 100 yards of it) went of without a hitch. Throttle response is awesome, Initial tune seems fairly lean... Gonna have to sort that out. mental note: need rear tie rods!
Robert,
Fittings fell through. Fixed the hard lines and left em.
May 07, 2014 03:23PM
got some dust on it and spent some time with it. Waiting on firewall material to show up before putting the windows back in.
https://www.facebook.com/photo.php?v=10154159544195473&l=4154546307698838617
to do:
Skid plate
firewall
Battery box mounted permanently
install handbrake
bleed brakes
1 way valve for vacuum brakes
fix oil leak from turbo drain
fix leaking power steering hose
install windows
Seat belts
trim
stickers
Get it registered again
TEST
Edited 1 time(s). Last edit at 05/07/2014 03:25PM by aj_johnson.
May 14, 2014 12:39AM
Slightly drunk
Brakes- Done
Handbrake- Done
Terrible trip- makes noise, plays music.. doesn't seem very loud (cept for music
battery- done
Handbrake-done
Made template for rear firewall... kicking my ass
More to do though...
Wipers/squirters
Trim/mirrors
Find aluminum tape...
Thomas Kimsey
Thomas Kimsey
1988 XRatty
May 14, 2014 01:53PM
Slightly drunk
Brakes- Done
Handbrake- Done
battery- done
Handbrake-done
Wipers/squirters
Trim/mirrors
Is that an Audi plug and play vems? Just wondering why the serial connector is in the box like that. Only seen the boxes with just the 2 econoseal connectors.
May 15, 2014 12:50AM
It's not a plug and play. Thats the output for an LCD or other such display.
May 20, 2014 03:00AM
