Re: XR V2.0 Build thread
March 17, 2012 11:37AM
Yeah Grant, The a-pillar bar in the old car covered the holes for the door bolts, that was one of the changes I requested..
The rear beam and arms you can talk to William at TSS about, but I would say in the $1000-1200 with the diff mount.
I have entertained doing another one at 6 degrees just to see what it would be like.
Mylesofsmyles
March 19, 2012 04:30PM
Interested in how those back windows turn out.....and did I read this is gonna be a 4x4???
Oh Baby!
March 19, 2012 05:13PM
2wd is where it's at! All the cool kids play there.
March 21, 2012 01:40AM
Productive night with Derik on the car. Fitted the front strut tie in bars, I made the pads for the strut tower, fitted the parts on the rear shock tower to give the cage a bit more room to land, and Derik made and fitted the brow bar.
March 21, 2012 01:45AM
You bending up a second set of tubes like I asked????
beebe
Chris Beebe
Sold them all!
March 21, 2012 07:41PM
Ya, or maybe a third! I cant take all these pictures anymore!
March 28, 2012 12:38AM
More progress tonight.
Derik at work!
March 28, 2012 09:54AM
How will those backstays fly with Rally America? IIRC, the Team O'Neil Mazdaspeed 3 had a similar setup and had to get a Canadian logbook because RA wouldn't allow backstays that didn't terminate directly to the bodywork. Something about shear, blah, blah, blah. Even LeMons would make you redo that.
Not trying to be a Negative Nellie, just hate to see you burned by the rulebook.
Edited 1 time(s). Last edit at 03/28/2012 09:54AM by fiasco.
March 28, 2012 12:47PM
I guess I could run a tube down to the frame rail. Gene?
March 28, 2012 01:28PM
Bars are fine for me...carry on.
March 28, 2012 01:45PM
Cool! Just making sure...
Gravel Spray
Location: ------------------------------------------------
March 28, 2012 02:29PM
Nice!! A properly fitted cage!
March 28, 2012 02:47PM
Thats because Derik is doing it Pete.....
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
March 29, 2012 05:30AM
So how did you guys get a weld all the way around the tops of that cage? Looking at the pictures it seam like the front stays are sitting on the floor. Did you cut the roof or what.
March 29, 2012 11:43AM
Notice the bottom legs stand on the sill ledge. That allows you to drop the cage 6-8" down to weld the tops then just box the bottom.
