Re: Swedish Endeavors: Project Rally Tractor
January 07, 2014 12:04AM
are you guys going to add a sill bar? I would suggest it.
January 07, 2014 12:21AM
Some reasonably light but ungodly TALL looking pistons arrived...
January 07, 2014 12:44AM
As they say in da yoo pee. Ya you betcha
Zap zap my ass...
January 07, 2014 12:45AM
Give you a call tomorrow
Zap zap my ass...
January 07, 2014 02:18AM
A pillar support bars look to be a bit too far down the A pillar at the top and they don't terminate at the base of the roll cage leg. Check the FIA rules. A hard hit on the corner of the roof could cause the cage leg to bend where the bottom door bar and A pillar support bar feed load into the tube a few inches above the floor mount. Think about triangulation!
January 07, 2014 02:02PM
The tops are within the distance specified in 253. They have actually been redone once to close that gal up a bit. As for the base does the inclusion of a sill bar ease your concerns at all? Dash bar and front strut tower tie ins also forth coming. Thanks. Glad to have your opinions.
Zap zap my ass...
sidewaez
Blake Lind
orange AE86
January 07, 2014 06:43PM
I'm going to add a sill bar but just haven't gotten to that stage yet, the FIA says the bottom has to be 100mm from the cage feet
January 09, 2014 09:37AM
Eric Ewert
Sweet, volvo number 2 with cage being built on here! Looking awesome. Looking at your floors/ footrest area, am I correct in saying that the drainage holes are all welded up?
EVERYTHING is welded up. I tried gluing the floor holes in while using it as a rallyx car and each time the floor would flex the bung would pop out. Lots of work went into this chassis to see hat dust and water would stay out.
Zap zap my ass...
Eric Ewert
Eric Ewert
volvo 240
January 10, 2014 08:10AM
Thanks for the confirmation. I wasn't sure if the point to welding all the holes up was for structural reasons or for something else. I've welded up some of the holes on mine but not sure how crazy I should go. Keeping water out is a important thing though, I will do the remainder.
January 19, 2014 11:39AM
Few more cage pics. Blake was working on mounting the codriver's seat yesterday. After that the sill bar will be taken back out so the seat mounts can be fully welded. Once the seats are mounted we can figure out where the steering column will end up. Then it is just harness bars and a few gussets. Pin stands will also happen while at primitive. Then I'm lucky enough to be trading some landscape construction for bodywork and paint prep. Go team!
Zap zap my ass...
open | download - image.jpg (45.1 KB)
open | download - image.jpg (49.2 KB)
open | download - image.jpg (53.4 KB)
January 19, 2014 11:51AM
Couple more pics. Really happy with how the front strut tower tie ins came out. Wish I had better pics of them all finished.
Zap zap my ass...
open | download - image.jpg (37.5 KB)
open | download - image.jpg (41.2 KB)
open | download - image.jpg (48.9 KB)
January 19, 2014 02:16PM
Winning!!!
fidel
lawrence knox
78" volvo 242
January 20, 2014 09:54AM
looking pretty good.
i'm assuming you will be using floor mount pedals and foot rest back from the firewall a bit , seeing the seat location? the reason i ask is i was just in a wreck in my 240 daily. i lost a outer tie rod at 45 and a second later was stoped by a tree. the tree contacted the car right out side the passenger frame rail , it colapsed the wheel and suspention almost a foot into the lower section of the firewall. might be something to consider.
the only thing i dont like is the sheet metal and bracing being removed from the rear quarter on the inside. yeh yolvos are tough , but the 2 door is soft in that are compared to a 4 door. you have lost the outer "cage" around your new one now. now a side impact has half the "crumple zone" before it contacts the cage. for side impacts i would suggest fitting a lower bar and center bars in the main hoop. and with the b pillar losing a lot of strength , i would be afraind of losing the door in a bad rollover and posibly having it come into the passenger compartment now. i know its rare, but i have seen several volvos lose their doors and one with it impaled between the a and b pilar. i think the lose of strenght to shave weight was not a good call.
lawrence knox aka fidel
knox motorspors
knoxmotorsports.us
Eric Ewert
Eric Ewert
volvo 240
January 21, 2014 09:36PM
Looks like your closer to holding a log book! thumbs up
Question... The reinforcement plates/box that the main hoop sits on, is there any sort of bracing within the box to keep the top from collapsing?
Edited 1 time(s). Last edit at 01/25/2014 02:15PM by Eric Ewert.
January 22, 2014 10:09AM
Gah! Every time I post something on here it's like going to trial. No fun. Sorry Fidel but that is my choice and it happens to be the same choice that many other rally car builders have chosen to make. The shell is much much stronger than your dd. stitched everywhere, 1 inch tubing at the sills. I fail to see how cutting out the structure for the backseat armrest is going to make my doors fly off. The 45s from the main hoop to the half laterals is stitched to the b-pillar and I could add more and more bars to the cage but really it would be safest to just park the damned thing.
Floor mounted pedal box, extended column, and stick. This all puts you closer to the strongest part of the cage. It is also the reason for door bars that some might consider too high. For side impacts I think the seats are in the best possible location.
Eric, the boxes do not have any interior structure but are made out of so pretty beefy gage plate. Yet another way to die in horrific fashion
Zap zap my ass...
