On the bar going across, rather than the one bolt everybody does, use 2 next to each other per side..the bar can't rotate around 2 bolt; it can around 1... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Sumpin like this simple thing might do. Whaddya think? I'm a fan of shoving the gun in the joint of the inner fender to firewall and stitching..as you see. Oh, look, nice motormounts, too. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Capri? Andrew Steere Lyndeborough, NH KB1PJY |
noypiesky Donald Wong Mega Moderator Location: Richmond, CA Join Date: 01/25/2006 Age: Ancient Posts: 55 Rally Car: 1980 Toyota Corolla |
What happened to this car? Was it ever done? Did anyone use it in a rally? Just wondering. ![]() www.performanceoptions.net |
Yeah it was eventually finished, and been run. Sounded way wicked.
Looks like the stuff all worked. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Here's a few pics of the 740 oilcooler adapter. I'm running it with a 2.5in DP and stock length filter. This can give you some idea of clearance issues that you might have. I still like the idea of remote mounting the filter and cooler plate, especially with a skid plate. This will be my DD, and my skid plate stops at the cross member. There's also some pics of the turbo drain and block adapter that I made. So much easier to work around then the stock hard line, and it seals better too! photbucket.com/thisthingsucksnow! |
It's a stock turbo block. The stock drain line/ hard line/ pipe/tube thing didn't actually seal into the block. I machined an aluminum plug with 2 1/8in o-rings to seal it from the elements. You can kind of see it from the picture that John posted. The album has the photos of the adapter plug. The lower fitting is going to be zip-tied to the cooler tube for added security, hoping to prevent the plug from coming out of the block. It shouldn't, it's a really snug fit with the o-rings... I'm just being overly cautious. |
