Re: 22R Toyota Turbo pistons?
August 10, 2012 03:28PM
tdrrally
john you are right not enough information, but its fun to talk theory
Meh....I'm too busy to just talk theory..
I reckon we don't have to discover any theories, our major problem is finding affordable ways to pull off what we know is good.
my old starion is mark bowers car now
Oh, good. It now has JVAB Sooper Bitchin Suspenders both front and rear and he said it's a amazing transformation how well it works now...
Basic car is not bad and not bad is pretty damn good.
Interstingly enough the heads on those old thANGS ARE SO CLOSE TO THE tOILETTA HEAD THAT IT HAIN'T FUNNY.
i found an xrtatty to be as quick as a non i/c starion
Well stock to stock...I think part of it is the Starions, while heavier, are geared decently shorter, like 3.64 for Xratty and 4.27 for Starion..That's enough to be quite noticeable.
i still would like to build a sierra 4wd, or an xr8
As a 2 wheel drive car, the 2300 is more than enough.
4x4, its fursure fun but I'm coverting mine back to 2wd for the gearing advantages of the T5 and short axle (4.3)
all i'm saying is vintage racing is a very fun sport.
Can be but its also a lot of fiddling, and I don't have time to fiddle.
tdrrally
edward mucklow
August 10, 2012 03:43PM
i will agree with that, its all what you'r out for i guess
August 11, 2012 12:30AM
John, he is not a cheap bastard, he did spend money on a nice manifold, in the $700 range. He is currently building a stock 22RET, with a nice intercooler, and fuel control to be determined soon. Stock Turbo head, Stock replacement Turbo pistons, nothing crazy. He just wants reliable, and a bit more poop that his stock 22RE.
He borrowed my Ford 2.3T Volvo wagon a few times, and could not believe he could accel from 60-80 in 5th, climbing a hill, at 1/2 throttle.
Well the tear-down guy at Foster's (the auto machine shop I've known for 28 years) his in-laws had one of these things 22RET and the T had to stand for Turd. After helping him set the ignition timing, THEN the cam timing correct and actually seeing if the turbine shaft was moving, ie not seized and made sure that at least everything was at a good "Stage Zero", I concluded it was just a massive pile of shit, and slower than fawk..
He was thrilled at the improvement
Then he drove my beater Xratty...
Like a number of other Japonaise junk, I think they purposely made them make no power, but mainly so they could put a badge on the back that reads "TURBO"
Sean, what does you guy want?
He want it to go as good as a stockish Xratty?
Is he really a cheap bastid? Does he want the thing to work for 3 months? 7 mo?
1 year?
August 11, 2012 02:27AM
stock cast pistons and a $700 manifold?
Oi.
Have at it.eye rolling smiley
August 12, 2012 10:52AM
Those are the pistons he already purchased, but was asking me what I would do, and I recomended a forged piston for security.
PM me anout that Haltech, price and such, and I will pass the info.
Ascona73
tdrrally
with an i/c go for it
there was a supercharger kit for that truck at one point
Still is, made by Camden superchargers. I had this kit on my own truck.
http://www.camdensuperchargers.com/
Dealers:
http://www.lcengineering.com/
http://www.pulleyboys.com/store/home.php?cat=72
http://www.lceperformance.com/Street-Turbo-Piston-Set-w-Rings-22RET-85-95-STD-p/1014310.htm
Crap LC engineering has the 22ret piston and ring sets for 160 bux. Any reason you need to have forged pistons? Factory Rte pistons were cast . was this the 22RE or the 22R?
If he wants I've got an old haltech fuel only ecu, wiring harness, manual and softwere that would be perfect for a budget turbo build. I even have some flow matched 300cc injectors for the experience.
August 12, 2012 11:19PM
Why the issue John? there is not much out there for turbo manifolds, and he wants reliable, that is why we are asking about better pistons. I did not say he was running the cast pistons...
Check out the manifold though, would be sweet if they did a ford 2.3.
http://www.steedspeed.com/22rte_internal_wastegate_turbo_manifold
Oi.
August 13, 2012 08:22AM
Well, they make a header for MY dream engine in a Yoda truck:
http://www.steedspeed.com/cummins_4bt_turbo_header
August 13, 2012 10:10AM
Jeebus those guys do some really nice work!
August 14, 2012 12:58AM
Yeah Gene, the manifolds are CNC'd in 2 halfs, then welded together. Seems like you could get some seriously smooth transitions in there with that process
August 14, 2012 07:22AM
They have some good pics in the E36 BMW manifold of the process. Pretty wild...
August 23, 2012 09:58AM
Ascona73
Like John said the chamber design and bore size are not ideal for forced induction. I ran 6 psi boost with the stock 9.4:1 compression ratio on 93 octane with no issues.
I later bumped the boost to 9 psi (non intercooled) and added water injection. Ran out of water one day and shattered #4 piston's ring lands.
Put in the 7.8:1 turbo pistons and it was reliable after that, but it felt faster with the low boost/ high compression setup. Certainly smoked the tires a lot easier...
Heya Bob, How are things? I can relate on the higher compression: we had a true 7.6 Cr in the Starion with the original 'not really stock' showroom stock pistons. Got some factory ones and the true CR dropped to 7.2 (despite the shop manual claim of 8.1); felt like the bottom end torque was all gone. JLV helped me get some flat top forged and the true CR is now 8.2: whole new engine, bottom end torque like you would not believe. Now running up to 15 psi boost on the later factory ECM, and the engine is super; REALLY good for rally use; bottom end like an older 10:1 NA engine, and the turbo top end. Geez, I gotta get that thing going again....
tdrrally
edward mucklow
August 23, 2012 10:18AM
hi compression low boost, quick spooling and low end too
August 23, 2012 11:04AM
tdrrally
sounds like a diesel.
But for the 10,000th time to forumers everywhere in the world repeating that: with never any consideration into bore size, flame front propagation, dynamic compression or any reference to intake closing ABDC which has major affect on "compression ratio"....
Fine on a motor with small bore, this first part, like whatever!
OoooHignH compression! Klow boost!! ooooh eye rolling smiley
But from a serious sense;
what the hell with the hassel of turbocharging, weight, cost, mapping, packaging all that shit, just to have "low boost"? "High" compression? What's high? low boost? what's low?
Bullshit.
And in a rally car where the mere presence of a turbo even on a totally stock 100+ mile beater guarantees even those just looking melt like this
and must be in the tottering evil empire only driven by "experienced" drivers
So all that pain in the ass shit and and the advice is "Hi! Compression" are forced to remain low boost..
That's real brilliant thinking ahead, and just wonderful advice..
tdrrally
edward mucklow
August 23, 2012 12:09PM
i'm talking 9-10:1
but i like a non turbo rally car (groupe 4)
i do like groupe D rally on the other hand
Edited 1 time(s). Last edit at 08/23/2012 12:12PM by tdrrally.
August 23, 2012 02:15PM
tdrrally
i'm talking 9-10:1
On a motor with a 90mm or larger bore, that's extremely high, even 9:1 especially for home built , crap head design motors...
have you noticed that nearly all modern motors have been going down in bore and nearly any 2,0 you can imagine in the last 20 or so years are down around 81.5 to 86mm except one or two (EJ20 and Duratec at 87mm?)
But look up the Duratec 87 x 83 approx for street car...But in the turbocharged motors for WRC, they ran 85mm bore and about 87 stroke...
Smaller bore tolerates higher comp or higher comp and lots of boost.
But they also have a nice head with a nice combustion chamber..
And what are you talking about Group(e)4?
Normal aspirated 2wd rally cars are generally in North America called "Group 2"...
You trollin?
