JVAB's own 50mm Soooper Bitchin Suspenders
Re: JVAB's own 50mm Soooper Bitchin Suspenders
April 16, 2014 04:32PM
Shipped.
When is it my turn?
Gettin there.
Will you make a second set of front 50s for the BMWs. Got a customer car that will need fronts.
Why not? The more the merrier.
Get pricing sorted?
cmm7v3
Chris Martise
1996 Impreza wagon
April 16, 2014 05:48PM
John, can you check your email and get back with me tonight? I am having a issue with the threading on one of your bodies.
April 16, 2014 06:44PM
cmm7v3
first: clean. use goood stiff brush. next lube, even soap. clean good below lock ting. then go down.. don't be a savage....those things spin freely when clean... work bacl and forth and if it jams, back off the other way and more water, gunk, soap, and even propane---followed by Gunk..
cmm7v3
Chris Martise
1996 Impreza wagon
April 17, 2014 07:28AM
John thanks for the suggestions. It took over an hour last night but I finally got the perch and locking collar unthreaded last night. Shock body threads were good, but the collar threads were apparently the issue. They had knicks in them in a few places. After cleaning then with a file they thread on and off now with no issues.
simoniac
Simon Wright
Rally Spec Focus
April 17, 2014 09:52AM
Had a similar issue. Dirt likes to get down there. I've taken to putting a bead of silicone sealant around the top of the body after setting the ride height. And, of course, I wrap some duct tape around the lower exposed threads. Figure it'll be easier to peel off the sealant than work out any dirt if I need to readjust.
Simon Wright
Owner/Driver USUK Racing - Home of the USUK Racing LED Light Bars!
North America Rally Map
April 17, 2014 10:06AM
Yeah lots of discussions on keeping dirt out. One thing I forget to say is a good whack in 4 positions occasionally to smoosush the dirt or rattle it loose.. ringht on the adjuster ring or flange or whaddever you call it. Good solid whack with plastic mallet
April 17, 2014 11:04AM
simoniac
I use clear hockey tape to protect the threads. It's doesn't leave a residue.
Robert Culbertson
Out of this dumpster fire
April 17, 2014 11:15AM
Fire hose zip-tied around the shock body also works. It's also reusable. Let me know if you need some, I currently have 300ft sitting in my garage.
April 17, 2014 11:26AM
Or a bike tube stretched over the thing.
April 17, 2014 11:42AM
John Reed took an idea I offhand suggested and used monster mutant heat shrink wrap....
I took a couple of spring seats and machined a groove on the ID of the raised portion of the lower spring seat and first tired a round O ring..No go, way too stiff, so I thried square section O ring, still too stiff to adjust...
I thought about a modified Acme thread but its so deep it makes other problems..
Seems the only workable solution is clean clean clean and clean again..
Robert Culbertson
April 17, 2014 06:38PM
I have a set of Cosmo sleeves for a road racing setup. They use a double nut, with the top one being plastic. They have survived ~800mi on track and ~2kmi on the street, and I can still adjust them easily.
The heat shrink seems like it would be awesome, but really expensive.
I would also worry about how much insulation you are adding to the sleeves. I know the tube/insert has all the fluid, but you probably want to keep them cool. Did anyone ever try running the shock cover/bags?
Cosmo sleeves
April 18, 2014 11:54AM
my current plan is to try a 1/2" tall neoprene sleeve around the threads above spring seat (just need to keep crap out of there). plan is to make it out of a beer koozie, I think the stock koozie diameter is larger than the 40mm threaded bodies but they make koozies for the slim cans all the cool kids have too.
cbombara
Colin Bombara
00 Impreza RSTI
April 19, 2014 06:36PM
JV- joo makin' me 50mm rears yet? LMK about the revalve on the fronts.
May 18, 2014 08:38PM
Lookie whats going in tomorrow's UPS---if the boys send some dough!!!
Volvos in Missouri and Calgary, WTF Volvos? Fawk yeah!
And Subaru in Colorado.. I am so suroprised.
I never heard of people rallying Subarus..
May 18, 2014 10:23PM
Where's the BMW stuff? Joe put his order in a year after I put in my deposit....
C'mon man! smiling smiley
