simoniac
Simon Wright
Rally Spec Focus
Re: JVAB's own 50mm Soooper Bitchin Suspenders
February 16, 2013 08:42PM
You've not forgotten Simon in North Carolina have you?
Simon Wright
Owner/Driver USUK Racing - Home of the USUK Racing LED Light Bars!
North America Rally Map
February 16, 2013 10:11PM
simoniac
Nope but I haven't deposited that check because I am increasingly uncertain we can make the date for Sandy Blast, and unsure what that meas for the order.
sidewaez
Blake Lind
orange AE86
February 17, 2013 11:24PM
sorry John couldn"t make it by today, I'll give you a call this week.
February 20, 2013 01:27PM
14 normal length tubes done--like Subie or VW or Audi whatever front
16 more cut:
4 rear Subie length--extra long
6 BMW front length..+2"
6 Normal length
I have to order about 105" of SAE 660 bronze, nice silicon/aluminum bronze
Another $350 of material...
And the checks are not flyin' in....
Gentlemen GENTLMEN!!!!!! Gotta turn up the heat
February 20, 2013 01:32PM
I blame the postal service!!!
February 20, 2013 02:11PM
Didn't get to it before I left. Coming at you march 1.
February 20, 2013 02:32PM
That's nearly 2 weeks..
There's this thing called Splay-Palz or sumpin that get's all that valuta here in seconds.
John Reed
John Reed
Toyota AE86
February 20, 2013 04:15PM
I am ready whenever but would be nice to know projected costs on these things and the associated parts to service them down the road should stuff get dinged up a bit.
John Reed
John Reed Racing
www.johnreedracing.com
johnreedracing@gmail.com
February 20, 2013 05:17PM
I'll figure something out. There is a nice check that is stuck to the fridge. I wanted to use that money...
February 20, 2013 06:17PM
John Reed
I agree, it'd be nice to know projected costs. I should ring the chrome plares. and hit "send" on the bronze but chips should be flying on the "special needs" tubes soon--later today or tomorrow.
February 26, 2013 05:53PM
Piccies will come as soon as I load the software into this machine.
But:
A)new tubes including 4 rear Subie length, 6 BMW length and 6 or so "normal" (Subie/VW/Volvo/Toyota removable) length done and in the car to drop off for plating.
B.) 21 shock shafts cut for screwdriver slot
C) 21 strut bodies back from chrome plating..
So as soon as I can pack alll the shafts and pistons and circlips and guts, the inserts can be sent down to Bilstein for valving and assembly..
Bilstein as of yesterday is about 7 weeks out on delivery
Blake, find the reciepts on the shocks you sent and get a copy to me...
William Timmins, you're going to miss your chance to get the shock shafts modded since you haven't got the shafts here...
Let's get what the top pins for each of you guys want nailed down:
A) 20mm big "Ford GrA pin" for mounting into 7/8" spherical bearing
B.) 15mm bearing seat for "Subie" style ball bearing mount
C) what have you????
AJ Audi? ..................................4 struts Audi ears+ steering arms
Blake Celica? ...........................2 struts ?? Ears
John Reed Corolla? 2 struts........2 struts....Subie
Rebecca Audi?..........................4 struts Audi ears+ steering arms
Dave Kern................................4 struts...fawking annoying BMW muffler clamps
Simon Wright............................4 struts Subie ears-----Subie tops
Now that the chroming is done, its REALLY time for more moolah from EVERYBODY
It came in more than was quoted for simple chroming, they polished the hell out of the things which I had said not to do, but they adjusted the price $300 but it was still around $33 per tube..
So youse guys, dig around in the couch and between the seats in the car and scrape some $$ up..
Now to find the software for downloading piccies from the camera.
February 26, 2013 06:02PM
Checked bank records and looks like you got the check from me.
Do I need to choose tops or is your plan to do the same deal as before?
Any word on making those offset top hats?
Muffler clamps? Isn't that the way the old E30 fronts are? You're doing up the same ears as the ones you did for me...though maybe a little bit different offset so we've got a tad more camber built into them, right?
February 26, 2013 07:05PM
Yeah Dave I gotcher check...
I reckon you're getting 20mm pin and I'll see the guy tamale (chilly today, hot tamale, eh) about the offset tops, so that'll call for some more moolah.. 4 or 5 would be smrat.
As for the muffler clamps on your fawking thing, my beautiful jig I made has to be re-jigged cause the thing was made to put 40s 52mm OD tube in the exact right place...Now with 5o inserts and 62mm outside on the tubes the centerline is different, the radius is different and you want more clearence..
Gawddam Nazi junk Maybe i can look at some of the big spender's suspenders to check centerline distances...
February 26, 2013 07:10PM
Should be looking to get 4 minimum. LMK pricing on those and I'll get with the other compact owner and see what he wants to do.
Here's #s from an email on spacing/tilt of the hub to strut:
I pulled the spacers I've been using at the bottom of the strut and measured them at 5.65mm thick. My thought is that if you're able to change that mounting angle slightly, we might be able to get away with more normalish camber #s to start with. Not sure if it makes sense to move the other pickup point near the bottom as well to create more tire clearance? I've not had any tire clearance issues, but thought I might if I tried to run some fatter rubber. I've only had 195s on it so far.
Also, both of us just ordered up new wheels and we bumped the offset ~10mm, so that should allow for even more tire clearance at the strut side.
February 26, 2013 11:16PM
Pretty piccies:
Dont pay any attention to those super long things in the back, I deny that there will be 12" travel on a car in near furure, that's crazy talk, that's up in the WRC league.
What would an ordinary schmuck Clubbie guy do with 12" travel?
Crazy talk.smoking smiley
