Re: JVAB's own 50mm Soooper Bitchin Suspenders
March 06, 2013 06:51PM
ETA on finished BMW soospenders? Dang 'ol hillclimb group shuffled around the schedule and first race of the year is now April 20-21 and second is May 11-12. Any chance we'll be rassin' on 50s?
I dunno, we'll see how long it takes to make another jig for that morphodite front glorified muffler clamp bolt up..
Jeeeez! I make a nice 40mm jig, sell one set and you just have to have 50s..
Wait! You have some nice stuff now!
Doooood we have to be careful cause we can't fawk up and we have to move things inboard. And spring clearance.
And make those top mounts...
March 06, 2013 07:12PM
At 2-4 miles ran 5-6 times throughout the weekend, the 40 mm stuff will be fine at the hill climbs.
The bigger question is will you have the BMW ready for a real rally this year? Idaho, Olympus, or Mendocino are all calling.
March 06, 2013 07:22PM
Not asking because of me - I've got the 40s which have worked great so far. Asking more for that other car because its slammed on its nuts on what I'm sure is a pair of heated springs and blown out OEM shocks.
March 06, 2013 07:33PM
Got a beat wheel you can send so I know what I have to clear??
March 06, 2013 07:40PM
Have a compomotive with a cracked lip...just ordered up some fancypants Braids for myself and the other Compact customer but I'm guessing fitment will be similar. My car has wider E46 front arms, but I suspect most will stick with the stock arms. On the new wheels we ordered up with an extra ~10mm off offset to give us more inner clearance so you can tilt things a touch. Figured with the increased camber we still won't need to worry about the tire/fender clearance.
Edit: car slammed back down on OEM struts now has 3-4 degrees of camber with the same spacers installed. Handled great on the ice! smiling smiley
Edited 1 time(s). Last edit at 03/06/2013 07:42PM by DaveK.
March 06, 2013 08:06PM
You send it yet?
What's the tracking number
Longer arms won't change flange to strut body/spring clearance will it? Thats a function of the knuckle design and the muffler clamps..
March 07, 2013 08:07AM
He's going to be lucky to be ready by junction.
March 07, 2013 02:13PM
Oooooooh looookie:
So fresh out of the platers they're still warm...
Heading out with these and hundreds of dollars of bronze...
Boys I still have to know what top mounts to finish these pins:
Need it all in one place pretty f***ing quickly.
Remember the choices are Ford Group A for spherical bearings
or Subie-rooo for ball bearing/rubber
OK you guys wanting 50s if you don't post the strut tops you want, I am going to..
John Reed Toiletta Commodah........2 x Ford top
Blake Lind Toiletta Sillycar...............2 x Ford top
Simon Wright................................4 x Subie top
Rebecca.. Audi.....................................4 x Ford top
AJ Johnson....Audi................................4 x Ford top
Dave Kern.......BMW..............................4 x Ford top
I'm heading down NOW to cut these tops.
March 07, 2013 02:19PM
Is that what you did for me on the 40mm ones? I'm fine with that as long as we're able to get some tops that'll work with them. Hopefully tops aren't like the cars...Fix Or Repair Daily.
sidewaez
Blake Lind
orange AE86
March 07, 2013 02:33PM
What size bearing does the "ford top" use, is it metric?
Where can I buy a shperical bearing to fit that?
sidewaez
Blake Lind
orange AE86
March 07, 2013 02:35PM
If it's the 7/8" bearing I'm remembering then yes go ahead and make them that size.
March 07, 2013 04:08PM
sidewaez
The pin is 20mm , the upper and lower stainless spacers take it out to .875" and incorporate a shoulder for the nut to hit on and make the normal sperical bearing into a "high misalignment" bearing..
22 is the industry standard seen on real GroupA stuff and 22 is .866"..but metric costs more so we go to the next step up and save some valuta
simoniac
Simon Wright
Rally Spec Focus
March 07, 2013 06:02PM
For us we're on the standard GC Group N for the rear and we have those fancy schmancy camber/caster Whiteline tops (Com "C"winking smiley . So they bring the front tops inboard and rearward about 3/4". Specs say "Extra +0.75 deg caster & -0.5 deg camber".
Simon
Simon Wright
Owner/Driver USUK Racing - Home of the USUK Racing LED Light Bars!
North America Rally Map
modernbeat
Jason McDaniel
March 07, 2013 07:07PM
If you do 14mm, 16mm or 18mm pins I can build spherical mounts including adapters. FWIW, the Vorshlag bearings have a 19mm ID.
Jason McDaniel
Edited 2 time(s). Last edit at 03/07/2013 07:09PM by modernbeat.
Creech
Scott Creech
Audi 90 Quattro (WIP)
March 09, 2013 01:38AM
So, John. Say (just for shiggles) "a person" wants a set of JVAB 50mm Soooper Bichin' Spusenders of their very own (or even say, the "JVAB 4Xmm Stainded-nerd Bichin' Spusenders" ), only - they want 'em for a vehickul that is highly-unlikely that JVAB has a Spusension Soloo-shun ('cuz like, NOBODY has any kinda Spusension Soloo-shun for this vehickul). WHAT pray-tell, would a person have to hold a tape-measure, piece of string, foot (with or without extra toes), bathroom-scale, whateva' - up against to say: "Hey there JVAB, the Spusension is X times Y by Z over three to the fiddy-fith power, carry the one and divide by three = yea-many inches/milly-meters long - gimme dat boinger wot's got that funky-green paint all-over it"?
Yeah, Ima.... erm, "a person" is chargin' their phone, right now....
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
Edited 4 time(s). Last edit at 03/09/2013 01:42AM by Creech.
