DexterVW David Baker Super Moderator Location: Rhode my Island Join Date: 11/20/2008 Age: Midlife Crisis Posts: 290 Rally Car: 95 GTI TDI |
Yeah some but then there's the damn 14" wheel thing seems most are saddled with.. You know some discs with a dia around 255-260mm and 4 on 100? BMW maybe? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
danster Haggis Muncher Mega Moderator Location: Haggisland UK Join Date: 01/04/2013 Age: Possibly Wise Posts: 409 Rally Car: VWs (for my sins) |
VW Golf mk2 1.8 16v from 1990 use a 256mm vented front disc, but the lesser mk3 diesels and petrols used a solid 256m front disc. Both 4 x 100. I'll check that disc fits the Polo rear hub tomorrow. Disappointingly not yet a Jackass |
Aaron Luptak Aaron Luptak Elite Moderator Location: SLC Join Date: 02/15/2008 Age: Midlife Crisis Posts: 776 Rally Car: Civic... |
The 'stub axle's from the 88-00 civic/integras will probably be a PITA to reuse, regardless of disc size. In addition to the stub for the hub itself, it has a stub going out the back, through the trailing arm.
best pic I could find quickly... However, the Fit uses a twist beam on the rear, and the hubs are the same AFAIK, so you might be able to use their stub axles. but: 1) no OEM discs on the fit (something like http://www.scarebird.com/index.php?id=44 could be fabbed though) 2) still have the 'bearing race is built into the hub'/not-really-intended-to-be-replaceable hub/wheelbearing assys. KF7RWG
http://www.utahrallygroup.com |
You can fit 10.1" 256mm rotors fine under 14" wheels. http://forums.vwvortex.com/showthread.php?846180-The-brakes-of-the-MK4-platform-OEM-and-Upgrades ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
My dog needed out for a piss so just picked up a front VW 256mm vented disc from the shed.
It fits perfectly on the rear Polo hub, it centres correctly, it's 4 x 100, even the little brake disc retaining screw is in the right place. And this also means the front 239mm vented or solid disc will fit. And just for info these Polo setups turn up over here secondhand for about £50 quid whatever that is in dollars. Disappointingly not yet a Jackass Edited 2 time(s). Last edit at 01/23/2013 05:18PM by danster. |
Since John is all about switching bolt patterns. The ford focus rear disks are a good setup. Focus pattern is 4x108. But it ticks the rest of the boxes, not sure on 14" wheels as I have never had a reason to try.
- Good caliper carrier - Replaceable bearing - readily available in junk yards - cheap - very durable I think Simon when something like 40 rallies and only had to replace them once. And that was because he did not install the dust cover for the bearing and it only made it 10 rallies or so. The second bearing went about 30 rallies. |
I found this pic of the early captive style front mount used on the mk2 golfs.
It certainly helps to keep the running gear located better than the later hydro types. It reduces movement both up and down and laterally. If you broke the box casing where the mount attaches it could be because there was either not enough, or inversley too much support or compliance in the mounts manifesting in too much load at a given point resulting in a failure. If the mount that broke off your box was a solid type and you landed heavily off a big jump the chassis rails may have moved with enough force to simply crack the box casing at the mount. If using the running gears as a "stressed member" this is something to consider. I have recently seen problems with the Ford 2.0 Duratec equipped vehicles. When they are involved in an accident unfortunately the engine mounts are not weak enough to be the sacrifcial part, this results in the mounts breaking the threaded mounting bosses off the alloy block. Pretty much rendering the blocks as scrap due to cost of repair and questionable strength for future use. I had to strip the engines out of 4 cars to finally get a servicable block due to damage in various different areas caused by similar frontal impacts. Disappointingly not yet a Jackass |
Does anyone have the diameter dimensions for the mk2/mk3 stub axle? I'm wondering if a custom turned axle to fit the mk4 hub could be persuaded onto the mk2/3 stub axle. I picked up a set of mk4 hubs, axles, and disks today. I can make them fit with some machined adapter plates, but that might be a little pricey for people without a mill/cnc at their disposal.
