Drew
Drew comer
1967 Cortina GT
Re: 1967 cortina gt
March 26, 2014 07:29PM
that roaster by the Anglia reminds me to gilles panizi at the catalunia
Ask, listen-read, research, learn, weigh, execute, then let er rip
danster
Haggis Muncher
VWs (for my sins)
Re: 1967 cortina gt
March 27, 2014 03:06PM
Drew
the tires look like 245 on these tarmac setups. wonder if I could stuff 235 under the rear without cutting up everything
Ha ha, wide wheels and Ford Anglias brings back memories of this old TV advert from when I was a lad.
(Health warning: Tobacco is bad kids, mkay)
Drew
Drew comer
1967 Cortina GT
Re: 1967 cortina gt
March 27, 2014 04:27PM
nice f1 tires : )
Drew
Drew comer
1967 Cortina GT
Re: 1967 cortina gt
March 28, 2014 06:49PM
This is what I remember
Drew
Drew comer
1967 Cortina GT
Re: 1967 cortina gt
March 30, 2014 12:06AM
looks like I may have found the best adapter plate to solve the t5 to duratec problem
a company called MULFAB in england mounts a adapter to the tailend of mt75 bell to mount a t5 gear box.
LexusFman
Yengi Lado
Age: Party Animal
I Ain't rich!!!!
Re: 1967 cortina gt
March 30, 2014 09:07PM
If you go T5, what gearset do you plan on using? I heard that the stock T5 ratios are good for a turbo 4 banger but not a N/A one...
Drew
Drew comer
1967 Cortina GT
Re: 1967 cortina gt
March 31, 2014 03:01PM
talked to a buddy that is into mazdas he thought a 2010 Miata 6 speed trans should be able to mount up to a 2.3 duratec that could solve cobleing things to gether and getting oddball parts and make build easier
question does 2.0 have same trans bolt pattern as 2.3 duratec?
Re: 1967 cortina gt
March 31, 2014 03:13PM
Drew
That would help if you were building a FWD car...
Drew
Drew comer
1967 Cortina GT
Re: 1967 cortina gt
March 31, 2014 03:16PM
north south engine in the mx-5 rwd for sure
Re: 1967 cortina gt
March 31, 2014 03:49PM
Ha. Miata "6 speed" not "Miata 6". My bad.
There was a ton of discussion about this topic a few months to year or two ago. Duratec into a RX7 discussion as I recall.
Drew
Drew comer
1967 Cortina GT
Re: 1967 cortina gt
April 09, 2014 03:14PM
2010 2.3 duratec out of a ranger on the engine stand and ready for surgery
2010 mx5 Miata 6 speed trans in shipping can't wait
found a the info I could and these two should bolt up nicely just hope flywheel is not problematic
so now 6th gear at 9k rpm=150mph, gotta do some more looking at wheel and tires
Mad Matt F
Matt Follett
Re: 1967 cortina gt
April 09, 2014 09:39PM
Drew,
I had been considering that combo for a B-GT, but couldn't find a transmission for less then 1500... what did you pay if you don't mind sharing with the class...
Matt
Drew
Drew comer
1967 Cortina GT
Re: 1967 cortina gt
April 10, 2014 01:13AM
its not a easy trans to find kind of rare really but a friend got a contact though his mazda buddy and found a donor car and myself and three others bought it to part out each person got what they needed so i stole it for 900. Ive seen prices from 1600 to 3000
i still have to get it after one of the guys pulls engine
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Re: 1967 cortina gt
April 11, 2014 08:18AM
9k RPM out of a 2.3L duratec is going to take some cash. What I have read says the ranger crank does not like much over 7,250. If you want to spin that fast you are going to have to spring for one of the steel Mazda cranks, which I do not know if it came in the 2.3L displacement, or aftermarket. Check out SBD or Cosworth.
Drew
Drew comer
1967 Cortina GT
Re: 1967 cortina gt
April 11, 2014 12:41PM
I wanna say the 2010 2.3 ranger was a steel crank but now ill have to check my info again
either way "yes I will have a strong steel crank"
