I'll co-drive with you. You will learn a lot. You will learn what "Gassa för fan, GASSA!''1 means ''Bromsa nu din djävul bromsa, nu dör vi altihop! 2 mean since you're in a Swedish car.. Other possible gems: Sover du?3 Ska jag ratta bilen eftersom du vägra?4 vet du att det är ingen transit vi åker på?5 hade du polio som småbarn?6 if anything goes wrong with any of the Bosch electrics, dizzy, fuel pumps etc you will learn some appropriate and juicy saksalainen,7 becuase if you don't swear at Nemeski 8parts in the language of their birth, how do you expect them to understand you? Naturally in honor of the amazing achievements that brave little Finland, 4 or now 5 million people who have done so much for rally, you will learn copious amounts of swearing in Finnish, the only thing any furriner can be expected to do without a lifetime of drinking to 4-5 pro mille BAC. See how much you've learned already? Footnotes: 1...Gas it for fucks sake GAS IT!!! 2...BRAKE NOW YOU BASTARD BRAKE! We're all gonna DIE! 3...you asleep? 4...shall I drive since you refuse to? 5...you know this is not a transit? 6....did you have polio as a small child? 7....German (language), in Finnish from saksa.....from Sachsen or maybe Saxon....Northernmost German province where a lotta rough tough dudes came from 8....nemenski German in Russian from the name of the river Nemen, historical ethnic and linguistic boundry beyond which its those same damn rough tough Germans Bonus 9.......tysk..Swedish for German...from Teutonic duddn't zat make you wonder where the name Germans came from when they call themselves Deutsch And the Romans who were stopped cold by them called them Allemani? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
shiza Dan Norkus Infallible Moderator Location: Goldsboro, NC Join Date: 01/10/2010 Age: Midlife Crisis Posts: 290 Rally Car: 94 Integra |
Let me get some new brake lines made first then lets start with the seat brackets. If that doesn't make it any better we can try the pedal. |
yea sorry, i had to leave and that open wheeled car dumping oil at the hillclimb didnt help things...
BUT i have more! First Rally: 2010 First RallyX: 2004 (a bunch) Driver (0), Co-Driver (7) Organizer (3), Volunteer (3) Cars Built (2.5), Engines Blown (2) Cages Built (0) # of rotations (3.5) Last Updated, Apr 9, 2023 |
You had at least one of mine. Black Butte Porter not good enough? Sean i'll give that a shot as soon as I can replace my brake lines. They are far too long and the left rear got pinched in the suspension loading it on the trailer. |
Yeah I pulled the wheel off and hand a friend pull the hand brake a few times. It's leaking right where the control arm and strut mount. Like you said it looks like it got pinched. There is a couple inches too much brake line so when I get the new ones made I'll have them made shorter. I'm having the fronts redone also seeing as they are probably 6-10 inches too long even at full droop. I'll get a better measurement Friday and head up to Boise to have those taken care of.
Next I want to find a short muffler that I can add to the back. I don't want it too quiet but it's beyond loud at this point. I want people to know I'm coming not make their ears bleed. I want to redo the center section in 2.5" piping vs the 3''. So I don't have to replace the cat I want to use the cat as an exhaust tip so I would really like to find a 2.5 inch inlet muffler with a 3" out. |
make you own so you can test them and tune/trim them before your locked in. Super easy. Even I can do it. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Just whatever you do, dont spend more than $30 on a muffler. I do have the old 2.5 in and 2.5 out that is in the 80 quattro right now. You can have it for free. A 6 pack at the exhaust shop here in nampa should be able to swage that out to slide inside a 3" pipe from there out.
I don't understand the 3" out though. To do that right you need a much smother transition than the half inch abrupt transition you get from swageing (is that even a word?) Other wise you create a huge cesspoolish area where exhaust velocity slows swirls and can cause restrictions. I'm no fluid dynamics major but look at your bike, and every performance full exhaust system for bikes or cars. One diameter from collector to tip. You'd be better off with a 2.5" system from collector to finish with some sort of glass pack style muffler in the middle. To change the tone play with the tip or with location of the glass pack. |
I guess I could just trim the old ones and test fit then bring it to the shop that will make the new ones? Sounds like it could work and would definitely be better than just guessing. AJ the only reason I want the 3 inch out or to have a 2.5" out adapted to the 3" cat is to save money on buying a new cat. Is the muffler you have just a stocker or what is it? |
That's why I make my own hoses using re-usable ends. You get it right, and you can change the hose for a couple of bucks. If it dies, you save the expensive parts and re-make the hose. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Yeah. If they are too long, figure out the length you want them to be and mark it.
To cut, wrap with electrical tape. Or just take it to a hydraulic shop and have them put a new end on for you. No need for a whole new line. So was it leaking during the hill climb? Grant Hughes |
