Oh, and I don't have a rack-boot solution for what you're asking. I just use the boots from the power rack. Generally I find the most hassle is getting the teeny cross-rack breather tube lined up with the little holes in the boots. Also, generally if I've done something severe enough to bend the tie rod, I've got other problems and changing the tie rod is only a small part of the necessary repairs. :/
Self-righteous douche canoe |
Ckgtimk2 Corey Kline Junior Moderator Location: Lancaster, PA Join Date: 11/22/2011 Age: Settling Down Posts: 103 Rally Car: Used and abused Mk2 GTI |
No but it is an old team oneil car. I think I saw CD's name in the log book though, along with 2 dozen other people... It was def the village whore. It's been called wrinkle top, or wrinkle tits or something... Less talk. More rally. |
This idea...it seems like a good one. |
I'll be happy to help out if I can. If anyone has experience with or connections to a shipping agent / courier, or someone travels across the pond occasionally feel free to pitch in. I once shipped an engine and other parts in a large consignment to Iceland and the purchaser arrange it all from his end. There may be other things to consider as options if there is a bit of interest. The mk4 stuff you do get over there may be viable to modify if there are more people interested. Just thinking ahead to the cost and future spares availability. Could the mk4 stubs be accurately ground down to accept the smaller hub bearing ID? A plate could be made to convert the stub to axle bolt mounting patterns and could also have the caliper lugs incorporated in it. Mk4 rear carriers have a different offset to mk2 and 3 carriers because the lugs are on the stub of the latter, but on the axle of the mk4. A conversion plate would also "wide track" the rear to an extent. Disappointingly not yet a Jackass |
I believe Wimpey's were working on adapting a MK4 stub, not sure I ever saw a finished product on it.
I think they actually cut off the end plates from a mk4 axle, ground them down, and drilled holes to bolt them up to the MK2/3 rear beam. https://www.facebook.com/pages/Quantum-Rally-Sport/ has some pics of the plates. |
Mr. K Chris Krepski Ultra Moderator Location: Gatineau, Québec Join Date: 02/25/2010 Age: Possibly Wise Posts: 31 Rally Car: 1991 VW Golf, 8V of fury! |
I've had my eyes on the VW Polo rear stub axle setup for awhile. If anyone arranges a group buy, I'd be interested. I can think of a few others here in Canadia who might be interested in it too.
Cheers, Chris Edited 1 time(s). Last edit at 01/22/2013 10:05AM by Mr. K. |
Er er er UHm . Uhm.! EEER! EEER! UM!!!!! If I could make a gentle suggestion before all the boys here cream in the jeans too much... Could you be kind enough to throw your hyper accurate Very-near calipers on the stubbie thang and tell us what od the stub is? And, for a wear item: is the bearing a "cassette" bearing of permanently in the hub? Boys are acting awfully eager like this is big discovery and I say it has to be crazy to have to go all the way across the seas to get wear items... Hell I can get things in their new country of origin---where VW makes more cars than any other, but first lets examine sizes, details before thinking about shipping--which is always a bitch. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 1 time(s). Last edit at 01/22/2013 10:10AM by john vanlandingham. |
Mon-sewer Krepski, it MIGHT be smarter to get readily available in North Amerique MK IV stubs---and if we can't adapt the 5 bolt into 4---and I know we can, then I bet it would be cheaper IN THE LONG RUN to make a hub here with replaceable bearings....and use existing rear calipers and adapt some nicer disc. c'est que tu ponce manure? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Je suis d'accord mon cher John. The Polo stuff is atttractive since it's bolt-on. But if we can make the Mk4 stuff fit easily, I'm all for it too.
I'm also curious if the Mk4 hub/bearing carrier will fit the Polo stub. At least that part would be taken care of. The Polo is sold in Mexico and countries to the south. I believe they were made in Brazil for those markets. Question is whether they had rear discs there? |
DexterVW David Baker Super Moderator Location: Rhode my Island Join Date: 11/20/2008 Age: Midlife Crisis Posts: 290 Rally Car: 95 GTI TDI |
Why fill with urethane? Drill some 1" holes in hockey pucks (I can't remember if you need three or four) and Bam! Stiff, cheap, clean engine mount!! |
Worked on it but it requires a lot of work to do... --Donor mk4 rear beam(s) --Adapter for the plates or weld them on without warping somehow ---Adapter for carrier to fit the increased offset ---5-lug nonsense A lot of work to modify a throw-away rear beam (and at least one spare). Would much rather have a bolt on option even at 2-3x the price. ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
Because in cars made out of twice folded over paper thin steel, it is nice to not shake the shell apart and rip the mounts out of the sheetmetal. Didya notice that real rally cars retain some rubber? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Terminology clarification request. Why donor beam? The stubbie thangs (technical term) are removable. Is the stubbie thang bolt pattern at least a bolt diameter bigger in all directions? With a nice flat drilling jig you could drill 4 hole nice and square real easy on existing beams.. What are the other things? Re offset, thought excercise time.... IF the stubbie thang and hub were attached directly to the MkII beam---would the wheel postion change? by how much? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
John, totally... and the hockey pucks seem to fall in that perfect range from the little experimentation I have played with... not as hard as the poly mounts (or random white plastic my car came with) and easier than the urethaned stockers... but like anything 100 ways to skin this cat :-)
