Welcome to the asylum intinerant Turbobrickers---plus any rally-Volvo pervs
Here's the safe house for the info. here's the list: ................................................Deposit sent 01. Patrick Helzer aka 700V............w 60-2..........................NO 02. Hallvard Buer aka RS1..w 60-2 and custom bolt circle...............NO 03. Eric Olsen aka Poik............w 60-2............................Jepp 04. Alex Morgan aka Lord Athlon ....w 60-2.......................NO 05. Alden Merchant aka WindowsBreakerG4....w/o 60-2................YES 06. Mattias Mellum aka Matti......w 60-2.......................Jovisst 07. Taliessin Penfound aka vertigosity..(2)..w 60-2......................NO 08. Taliessin Penfound.......................................................YES 09. Alex Nordenson aka Manimal......w 60-2..................................YES 10. Albatros Kunkannennen aka megulon-7....w 60-2...................NO 11. Brian Smith aka brian smith...LH2.4 - Normally Aspirated, clutch type undetermined as of yet........YES 12. Pat Darrow ....w/o 60-2.......................NO 13. Arne Saevik aka surre_sprett...BMW Pressure Plate.w/60-2...........Javisst, pengar är här 14. Dan Halli aka dhallilama..Saab 9000 pp, no 60-2.............NO 15. Chris Floren aka Duder...w 60-2..................YES So anybody HERE need to get on the list? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 7 time(s). Last edit at 10/06/2011 10:34PM by john vanlandingham. |
Duder Chris Floren Elite Moderator Location: Torrance, CA Join Date: 09/28/2011 Age: Midlife Crisis Posts: 1 |
SteveL Steve Leitch Elite Moderator Location: Ocean Shores, Washington Join Date: 01/25/2009 Posts: 280 Rally Car: Can't decide which to use... |
Maybe you should read this and fill out your profile... http://www.rallyanarchy.com/phorum/read.php?8,41104 SteveL This is the point in the killing spree when you really should turn the gun on yourself |
slidewayswrx Patrick Darrow Mod Moderator Location: Portland OR Join Date: 12/30/2006 Age: Midlife Crisis Posts: 379 Rally Car: Swedish John Deere |
Magnum TE Toby Eidelman Ultra Moderator Location: Santa Rosa Join Date: 10/12/2011 Age: Midlife Crisis Posts: 57 Rally Car: '92 Volvo 940T (tarmac dweller) |
Updated. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 7 time(s). Last edit at 10/24/2011 01:45PM by john vanlandingham. |
Updated.[/quote] John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 2 time(s). Last edit at 11/06/2011 03:29PM by john vanlandingham. |
So I am feeling nervous that I am just one of two that are not asking for the 60-2. I am planning on running Lh2.2. on a B23 block. 60-2 is only for 2.4 with the head mounted dizzy, correct?
Would I need the 60-2 in the future if I went with standalone? would I be able to run 2.2 with the 60-2 holes? Ease this youngin's worried mind. Learn me |
fidel lawrence knox Senior Moderator Location: RVA richmond va Join Date: 03/11/2007 Age: Midlife Crisis Posts: 61 Rally Car: 78" volvo 242 |
volvo LH2.4 uses the 60-2 for the crank signal, and it uses a head mount dizzy on a 740 and a block mount on 240. you can't run LH.2.2 off of a 60-2 signal, it uses a 4 window hall effect in the dizzy. it would not hurt anything to have the 60-2 flywheel for EFI upgades down the road. with the b23 block you will have to do some machining to mount the factory sensor bracket to the block, or weld a mount to the bellhousing for it. trigger signals for standalone EFI systems varies. electramotive is only setup to use 60-2 for the crank signal, were other sytems can be configured for 4 window hall efect, 36-1, etc. if you go to a sequential setup you will also need a cam signal, there arn't any factory options for this if you have a 240. if you have a 740 a 2.2 740 dizzy can be modified by cutting off 3 of the 4 tabs on the tone wheel. there are other options for crank and cam signals aswell. there is a DSM cas adapter that goes were the block mounted dizzy goes (it can be used for both crank and cam signal). there are also edis trigger ring (36-1) adapers for the crank pulley . you could also fab up sensors to work of of the cam gear, crank pulley and/or flywheel with magnetic sensors. |
