Thomas Kimsey Thomas Kimsey Junior Moderator Location: Rochester, New Hampshire Join Date: 10/05/2013 Age: Settling Down Posts: 271 Rally Car: 1988 XRatty |
MConte05 Matthew Conte Mod Moderator Location: St. Louis, MO Join Date: 06/27/2011 Age: Settling Down Posts: 257 Rally Car: 1991 Subaru Legacy Turbozzzzzz |
Nope, they're for sure a good deal higher than 4-5 years ago. Same with Volvo 240. Drive a bit and deals can be found: http://detroit.craigslist.org/okl/pts/4289834545.html Merkur XR4ti Parts see pics and Scorpio Ford (Pontiac) image 1image 2image 3image 4image 5image 6image 7image 8image 9 © craigslist - Map data © OpenStreetMap (google map) (yahoo map) Scorpio and Xr4ti parts parting out 89 Xr4ti motor knocks c3 trans car still together Gray Leather interior Seats have good leather the drivers has a little wear (holding for someone) Hatches What do you have in mind? evil intent? Willing to drive how far? (You see the Estonian guy over the week-end? He's ready to leave his country to go get a 240 Volvo..those boys don't mess around!) John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Closer:
CL >new hampshire >all for sale / wanted >cars & trucks - by owner x prohibited[?] Posted: 29 days ago 1989 Merkur xr4ti - $1000 (Saugus ma) image 1image 2image 3image 4image 5image 6 1989 Merkur xr4ti automatic transmission Selling my rare Merkur XR4TI its a 2.3 turbo ford motor RWD, auto. Just blew the head gasket, I have 3 other vehicles and I'm trying to finish my project. Recently replaced the auto C3 to a known good one no slipping (that's why changed it to begin with) new front rotor,calipers, and pads since they didn't exist when I got the car. Manual boost control, mk3 vw front bumper and lip. New plugs, wires, ignition module, coil, valve cover gasket. I upgraded the MAF and ecu to a 3 inch t-bird MAF and ecu to calibrate it. Looking for $1000 call or text 781-316-5585 I may be interested in trades but I could use the money. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
MarkHille Mark Hille Senior Moderator Location: The hills of CT Join Date: 10/04/2011 Age: Midlife Crisis Posts: 135 Rally Car: I have two crap boxes |
Watch out for rust under the plastic sill covers. Fixing a rotten car can easily overcome the time and effort you need to put into leaks and head gaskets. I would be willing to pay much more for a rust free shell than a $500 pile of crap at this point. That is assuming you are going to race it and not just beat it around town. A little rust under the plastic covers might help you to bring the sellers back down to reality also.
John, how common is it for the head gaskets to go on the 2.3 and is it any cause for concern? Also I had the idea that I wanted to get a car with a type 9 so I could have manual right off the bat but how intensive is the T5 swap? Edit: Nevermind that car has been sold Edited 1 time(s). Last edit at 03/11/2014 03:55PM by Thomas Kimsey. |
Yeah rust free and New England doesn't work. Seems like the guys who have the rust free examples out west know it and reflect it in the price. |
HiTempguy Banned Infallible Moderator Location: Red Deer, Alberta Join Date: 09/13/2011 Posts: 717 Rally Car: 2002 Subaru WRX STi |
$1000 is the new standard for a running/driving piece of crap up here as long as it will pass an inspection. I used to be able to buy cheap cars for $500 or less all day long, fix them up a bit, drive them, then sell them for a bit of extra money. Not anymore Hell, a 92-00 Civic that isn't rusty, is $2500+ up here with 200,000miles on it :0 |
Damn successful people, ruining it for the rest of us. |
You really think so? There are (IMO) less and less mechanically savy/car inclined individuals out there doing exactly what I do/did. Maybe the ability to have easy access to listings via the interwebs has just exacerbated the problem? |
I've had Xratties go years and years with no problems and others inexplicably blow gaskets with light foot on stock stuff.. At this point I say that part of the problem is guys be trying all kinds of "brilliant ideas" like mondo turbos and dumb cams and trick injectors and be pounding on them, blow the gasket and they'll will surface head 2-4 times--after maybe overheating things good.. EVENTUALLY somebody---the next owner probably---is going to have to deck the block to get it back to the "stone-ax" reliability... Natch that means engine out and crank and pistons out... So that's what I asked what you have in mind.. Cause if its for a rally build then we look at it as a good opportunity to do a simple freshen up.. Cranks almost never need anything thanks to a BIG and good pump...USUALLY the rod and main bearings are fine for re-use... Pistons, MOST of the time they are fine--good German Mahle forgings, finished in Brazil . Valve springs should be checked Auto to T5 is easy just need the front half of a manual prop or eliminate the Guibo and re-tube the front half. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 1 time(s). Last edit at 03/11/2014 04:38PM by john vanlandingham. |
Plan for me is to do some cone squishing (RallyX) to get used to the car on dirt/snow/gravel and improve my driving ability. Then once it makes sense go to stage with the same car. |
OK in order of things to do: DIFF Brakes tip top Some kind of cheap struts--KYB GR2 Fronts will do... And of course the RIGHT T5 (flywheel, disc and PP is easy, pedal sets is easy, clutch cables are cheap new) Have you seen the Supra diff mounting kit? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Yeah I have seen the setup for the Supra LSD. The first step for me is finding a car and getting it in decent shape. Working on a graduate school budget for the next year will limit what I can do until I start working full time next year. |
