Swedish Endeavors: Project Rally Tractor
Posted by slidewayswrx
Re: Swedish Endeavors: Project Rally Tractor
February 02, 2013 03:54PM
Thats what I wanted to hear John. We noticed they were doubled up but were pondering a bit more meat in there. We were thinking that might be overkill be if we were to do it, the time was now. We will just skip it. the brace I will be using also uses at least two, if not all three of those bolts, further transferring those suspension loads.
On the bar going across, rather than the one bolt everybody does, use 2 next to each other per side..the bar can't rotate around 2 bolt; it can around 1...
February 02, 2013 06:50PM
May I also recomend plating the "Frame" legs that are immediately in front of the firewall. I have welded up a pretty large crack there twice now on my Folvo Wagon.
February 02, 2013 09:15PM
Sumpin like this simple thing might do. Whaddya think?
I'm a fan of shoving the gun in the joint of the inner fender to firewall and stitching..as you see.
Oh, look, nice motormounts, too.
February 02, 2013 10:19PM
Capri?
February 03, 2013 12:00AM
Mine has cracked on the outside of the rail, right at that location. Mounts look great!
noypiesky
Donald Wong
1980 Toyota Corolla
February 03, 2013 10:40AM
What happened to this car? Was it ever done? Did anyone use it in a rally? Just wondering.cool smiley
www.performanceoptions.net
February 03, 2013 12:09PM
Yeah it was eventually finished, and been run. Sounded way wicked.
Looks like the stuff all worked.
Robert Culbertson
Out of this dumpster fire
February 07, 2013 02:41PM
Thanks for the tip Robert. I will add it to the list
Stay the course...7" father under the manifold, over the engine mounts.
Look first.
The Perma cool block off is under 15 and the DUAL inlet/dual outlet is around 27.
Dual inlet/dual outlet means you can place this behind the Pass side headlight, easy location and use the extra outlet to feed the turbo nice fresh cool oil....
And the extra port gets a reducer bushing where a T goes for the Volvo combined idiot light sender/oil pressure sender and oil temp...
Steady!
Here's a few pics of the 740 oilcooler adapter. I'm running it with a 2.5in DP and stock length filter. This can give you some idea of clearance issues that you might have.
I still like the idea of remote mounting the filter and cooler plate, especially with a skid plate. This will be my DD, and my skid plate stops at the cross member.
There's also some pics of the turbo drain and block adapter that I made. So much easier to work around then the stock hard line, and it seals better too!
photbucket.com/thisthingsucksnow!
February 07, 2013 03:01PM
Robert Culbertson
Look first.
Steady!
This is a Private Album
Please enter the password from album culberro to view this private album.
Private Album Password:
Note: cookies must be enabled and not blocked
Robert Culbertson
February 07, 2013 03:04PM
Annnnnnd fixed!
Hey, the link worked for me smiling smiley
Edited 1 time(s). Last edit at 02/07/2013 03:07PM by Robert Culbertson.
February 07, 2013 03:34PM
Robert Culbertson
Annnnnnd fixed!
Ugh.
Robert Culbertson
February 07, 2013 03:55PM
Yes?
February 07, 2013 05:11PM
My computer only lets me see photofuckit for a second, then goes blank...
How didi you hook that oil return into the block? Tap it?
Robert Culbertson
February 07, 2013 05:34PM
It's a stock turbo block. The stock drain line/ hard line/ pipe/tube thing didn't actually seal into the block.
I machined an aluminum plug with 2 1/8in o-rings to seal it from the elements. You can kind of see it from the picture that John posted. The album has the photos of the adapter plug. The lower fitting is going to be zip-tied to the cooler tube for added security, hoping to prevent the plug from coming out of the block. It shouldn't, it's a really snug fit with the o-rings... I'm just being overly cautious.
February 07, 2013 07:25PM
Looks kinda like mine but my oil return line is way longer and loops. It was what i had and I can move turbo way out of way without breaking oil lines. Or was...
