KTurner Kevin Turner Ultra Moderator Location: Newark, DE Join Date: 01/27/2006 Age: Midlife Crisis Posts: 364 Rally Car: 2wd Impreza... dude you should do an sti swap |
I've run both yoko A035's and DMACK grippa 3's in 14" sizes and prefer the DMACKS. The yoko pattern rounds the shoulder blocks pretty quick where the DMACK seems to have worn better with the classic M4 pattern. Also, check the dates on any yoko's if you get them. Last year it seemd that everyone getting the 14" yoko's were getting ones that had 2008 stamps on them, this quickly showed up as small cracks at the base of the tread block due to age/storage. DMACKs seem to be a little fresher.
-KTurner Stomp down on the exhilarator and hold on to the wheel. |
Mitsudriver274 Michael Rodzinski Elite Moderator Location: Bellingham, Wa Join Date: 05/29/2012 Age: Settling Down Posts: 21 Rally Car: 2006 Evo IX SPGT |
I love this forum board, awesome replies!
Andrew, Adam, Chris, and Kevin thank you so much for the input. It looks like Dmack is the tire to run. Gene I contacted ACP and am waiting for his reply, I had a lot of questions! Thanks again! I was thinking earlier about under body protection in regards to the rear suspension components. I know the rear arms are pretty soft and will bend from gravel spray, what do people run for protection? Looking at most cars they seem to run a thin sheet of plastic. I'm not sure what materials would work well? UHMW? I'm also looking for some trick ways to mount the sheets to the control arms. I've seen some people just use large zip ties, but I would like something a bit cleaner. I think the nicest looking installation used a U bracket with a quick release pin up top, but I do not know how well that works in reality. On that same note what do people do for the front arms? On my old galant we did nothing, and payed the price We would at least have to box the arms, or they would be beat after two rallies. And even then they wouldn't last longer than five. Does anyone here have experience in laying up carbon/kevlar skid plates? Sowa Motorsports #274 M.Rodzinski Attending: WWU ~ Vehicle Design WWU Formula Sae: Powertrain Previous: 1990 Galant Vr4 (Open) <= Sold 2003 Evo VIII (Open)<= Sold to Joseph Burke Current: 2006 Evo IX (SP) |
I use HDPE, it is way cheaper than the UHMW. The underbody needs to attach loosly to the rear arms because they move through an arc that is not in the same plane as the sheet. Attach them snugly and the attachment will fail. Bungee chords work well. Vermont does a aluminum U riveted to the sheet, and a hitch pin thing, it works well, but the u is larger that the arm.
To attach the sheet to the car, I run a piece of 3/4 sguare tube down the pinch weld with M6 weld nuts every 12" or so, then weld M6 weld nuts directly to the floor or "frame rail" for the indoard. It is one continous sheet from front to behind the rear arms. ![]() In this picture you can see the control arms and compression struts I made, the skidplate, and the underbody protection ![]() |
For Brakes the plan so far consists of:
Front: 2g eclipse calipers, slotted rotors with porterfield pads. Rear: Not 100% sure, we were able to get the stock brakes to clear but that was with wheel spacers, I would like to move away from that setup. Have to look more into this, any advice is appreciate here! Stainless steel lines to hard body lines. Using the OBP brake unit, with balance bar for the evo and hydraulic hand brake. Sowa Motorsports #274 M.Rodzinski Attending: WWU ~ Vehicle Design WWU Formula Sae: Powertrain Previous: 1990 Galant Vr4 (Open) <= Sold 2003 Evo VIII (Open)<= Sold to Joseph Burke Current: 2006 Evo IX (SP) |
unitedterra Andy Lord Super Moderator Location: Oshkosh, WI Join Date: 06/29/2012 Age: Settling Down Posts: 2 Rally Car: Not rallied yet Evo IX |
As far as brakes go you might want to look into Thompson Racing Fabrication. Ryan (the owner) built a really nice wilwood 4-pot front setup that uses rotors only an inch smaller than stock that still fits under 15" wheels. His tests show only a few percentage loss over OEM for braking, which is pretty good for smaller brakes. His cost is a lot lower than the other setups as well. He has a thread up here about it: http://www.dirtyevo.com/showthread.php?t=936
Hi_____________, You might have missed this:RALLY ANARCHY RULES - READ THIS FIRST (that means you, newb) August 13, 2010 05:30PM Admin Registered: 12/18/2005 Posts: 17 WELCOME TO RALLY ANARCHY! This site has been created with the goal of creating a proper rally BBS for the North American scene, for the people who love the sport and hobby. It's based on the idea of Sailing Anarchy, check it out if you want a sample. And by proper, I mean highly improper. Most things that will get censored on other Forums is fair game here. Proceed at your own risk. Note that the webmaster is not responsible for the views or opinions posted on this Forum, in a very real and legally binding sense. That's not to say there aren't any rules here. On the contrary, one sure fire way to get booted is to act consistently stupid or take personal attacks too far. Another is to whine or bullshit incessantly without contributing either knowledge or humour to the discussion. Any malicious quoting out of context to seriously deceive (rather than just poke some fun and obviously josh around) is grounds for ass kicking. Ditto on posts complaining about spelling or grammatical errors. If you are convicted by a jury of your peers, you may be sent to the Sin Bin for detention. Here's an example of rules you won't see here: Quote "I figure that hosting a forum is a lot like inviting a diverse group of adults to your living room for a discussion that can edify anyone who cares to listen and respectfully participate. Were it my living room and a handful of guests insisted on ignoring common sense rules of decorum by interrupting discussions with personal attacks, derailing trains of thought to further some unrelated agenda, consistently abused their participation privilege by carrying on one's business on the premises or uttered anything that might make a libel attorney salivate then I'd certainly never invite them back." That's fine and dandy, but we need a place to talk openly, especially if it's in a yakking-around-the-garage after dropping-in-an-engine kind of friendly banter. Think of Rally Anarchy as the local clubhouse you probably have never had. Swearing is OK, but don't go overboard. One of the things you won't find here is 834,234 different forums for every different country, region, state, province, city, neighborhood, gender, shoe size, sexual preference or hair colour. If you've got something to say, why don't you say it to the whole class, hmmmm? Required Information We hate cutesy account names like "FastDriver" or "WRCbound" or "PlumSmuggler" or whatever, but people get attached to their favourite account names. However we want to know who you actually are, so you must have the following information in your Member Profile: Full (Real) Name City and State/Province Car(s) you rally (we don't give a rat's ass about your street/track cars) Year of birth That way we know if you're some crusty retired old guy, or a clueless kid having wet car dreams, and can make fun of you accordingly. To edit your profile, sign in and click on "My Control Center" or just click here: Go to Control Center Want to put an exciting action shot of you driving (or co-driving) into the upper left hand corner of every page? Just email your reasonably-sized JPG to cornerpic@rallyanarchy.com Got suggestions on edits/additions to this page? Click on the PM link at the top of the post to send me a private message or send an email to webmaster@rallyanarchy.com Rally On! I highlighted the fun bits.. I see that set up is on your car... I like them Evos...... so much better than those Blue Sub-a-rats Wish there was one convenient round here so I could make a nice brake kit... I make nice kits, you see.. well pretty good for us lowly clubbie type guys.. Seen the nice kits I do for the Xratties? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I would love to see some of your brake kits John, I'm a fan of keeping my business local if I can, that way if I need help/support/parts I can just drive over.
All of my experience with brakes have been basically the same setup. Oem rotor that we slot, Oem calipers that we rebuild, and porterfield pads. Even with my heavy left foot I had very good bite with little fade, usually only having problems on the downhill stages at Oregon trails. We tried numerous different pads, but that setup was cheap (compared to a brake kit) and parts were easy to find. All of this being said, I have never tried an aftermarket setup on any car, so I have no basis of comparison. Sowa Motorsports #274 M.Rodzinski Attending: WWU ~ Vehicle Design WWU Formula Sae: Powertrain Previous: 1990 Galant Vr4 (Open) <= Sold 2003 Evo VIII (Open)<= Sold to Joseph Burke Current: 2006 Evo IX (SP) |
I've been running these on my hillclimb Evo since 2008 when I needed to have 15" wheels on the car:
http://www.amsperformance.com/cart/AMS/Wilwood-Mitsubishi-Lancer-Evolution-Evo-4-5-6-7-8-9-10-Rally-Front-Brake-Kit.html Full disclosure - they built the kit at my request and have sponsored our team for the last 4 seasons. Dave |
Yeah that's a little more like what I have in mind, but estimated closer to $900. But Superlite's 125mm long pad, correct piston sizes... I wonder how much deeper the hat can go. It's always the steering arm that limits inboard placement of the disc but ever mm more inboard means another mm bigger chance a larger variety of wheels will clear the outboard portion of the caliper.. Been doing something like that with the radial mount caliper for a very fast road car Xratty: 13 x 1.25" That 11.75" x 1.25" is what we did for Volvo 240 pervs and managed to get it under maybe 3 OEM wheels John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
What did you run on the rear with these Dave?
Full disclosure. I've rode with Dave with these. ~$1600 includes two calipers, two piece rotor, pads, braided lines, hardware, and rotor/caliper assembled with safety wire. Seems like the way to go to me. You could probably do it cheaper, or you could also just get the AP setup that's designed for rallying... Grant Hughes |
Stock rear calipers fit under Compomotives and Team Dynamics so I never felt the need to replace them.
FWIW, I've just upgraded my tarmac brake setup from the OEM Brembos to a radial mount AP setup, so after Pikes Peak I'm going to investigate having a new bracket made. That way I don't have to re-bleed my brakes when I swap it from one surface to the other. If I can make the APs fit under a 15" wheel...the Wilwood setup will be for sale. Dave Edited 1 time(s). Last edit at 07/02/2012 01:46PM by DaveK. |
http://www.smileysracing.com/shopping/productDetails.aspx?i=96765&c=1718
They even have them in titanium so they won't add too much weight to the car. ![]() Plus could make tie rod, strut, CV, bearing, etc work easier as you could easily pop the caliper out of the well to make room. Might pay for itself in brake fluid over enough time. Grant Hughes |
Hmmm...buy more parts, add more complexity to the system, or sell the spare kit I've got. Dont' forget, Val's got a CNC machine and has offered to help making brackets for the APs. Dave |
