simoniac
Simon Wright
Rally Spec Focus
Re: JVAB's own 50mm Soooper Bitchin Suspenders
October 21, 2013 03:58PM
this piccie is the key thing, fill the gap
any decent grease. I used to use moly-grease, the stuff used in your CV joints cause it is intended for very high pressure applications, but reports from the field seemed to indicate that it needed more frequent re-greasing. So now I use thicker grease for wheel bearings..
Matt,
If it's not clear I think John means to fill the gap that you can see a couple of inches down the tube. I use Liquid Wrench Marine Grease and apply it with a length if 1/2" wide aluminum flat stick. I try to evenly fill that gap without leaving too much on the inside of the rest of the tube. Then I gently insert the shock and rotate it as I gently push it down to use the shock to redistribute the grease in that space. Then I pull it out again and remove the excess that's accummulated on the end of the shock and reinsert.
Make sure your breather hole at the end is not blocked.
Simon
Simon Wright
Owner/Driver USUK Racing - Home of the USUK Racing LED Light Bars!
North America Rally Map
October 21, 2013 05:02PM
A good friend and rallyist and professional mechanic/shop owner regreased his inverted struts last week. He had to redo it on Saturday as he didn't grease them enough.
October 21, 2013 06:06PM
He'll be more careful next time.drinking smiley
October 26, 2013 04:55PM
John, set you a pm with all the images. Call you in a few.
Here is pic of the strut top in its hole...
Edited 1 time(s). Last edit at 10/26/2013 05:00PM by aj_johnson.
October 26, 2013 05:30PM
flip the upper piece.
didya find the big steel easher?
alosix
Jason Powers
October 30, 2013 06:31PM
You have (or anyone for that matter) have any pics of the sub-a-rat Group A style top hats?
This isn't floor mat anarchy
October 31, 2013 10:49AM
alosix
Here's what they looked like.
October 31, 2013 12:16PM
alosix
Dayum, muchachito, thems pretyy..like in pretty close to these---'except these ain't blue cause I made them overnight and had to get them out to somebody so they could win Black River Stages overallsad smileyand these are rear so no offset like the ones getting anodized in a couple of days)
How'd that happen?smoking smiley
October 31, 2013 12:17PM
Surely the BMW ones you made are blue...right? winking smiley
alosix
Jason Powers
October 31, 2013 12:20PM
Ah.. and yes.. pretty blue ones please when they get back (just drooling)
Looks like the front ones might be able to do friendly things to camber/caster.
Now it looks like they mount on top of the strut tower right?
Mostly trying to make sure I don't stick something in the way to stop from having the ability to run such things.
Thanks
Jason
Edited 1 time(s). Last edit at 10/31/2013 12:26PM by alosix.
October 31, 2013 01:00PM
Group A ones are offset back and inward for more camber and caster.
Interesting that whole thing is above the strut tower...
October 31, 2013 01:33PM
Because maybe its not rocket science? Those hats only take one turning and one milling operation. Hopefully they're not 6061 winking smiley
same with wrc they all bolt up above the tower.
October 31, 2013 01:35PM
same with wrc they all bolt up above the tower.[/quote]
Is that because of increased room for travel? Seems like it'd be easier for bolts to fail than for a top hat bolted in under the strut tower to get pushed thru it, no? Guess...just use bigger bolts and washers?
Iowa999
no-one of consequence
October 31, 2013 03:11PM
Also, the higher the actual pivot point (i.e., the center of the spherical bearing), the better the geometry ... usually.
October 31, 2013 04:31PM
Its mostly for ease of serviceability. As for the bolts to fail, its not that easy, a grade 8 bolt has over 10000lbs of strength, that times 3 its going to be easier to rip the sheet metal than to break the bolts.
Iowa999
So is it "usually" better or not? Or are we just posting for the sake of posting???
