Re: JVl Focus rear suspension and disc conversion
April 13, 2013 05:45PM
Nice negative camber for those high banking ovals and all.
April 13, 2013 06:31PM
kinetic
John's Focus suspenders came in and we mounted them up. Check out the travel on those suckers...
Is there an engine in the car? And a box?
Why would up so high?.. Sink that bugger down.
kinetic
Guvernor Eric Jones
Subaru + Ford
April 14, 2013 05:58PM
The car is completely stripped..... Box goes in this week, then engine and trans back in.... Stock Suspenders currently in there, the site of it just cracks me up, hence the joke photo, kind of reminds me of those stadium trucks..... looking forward to getting your suspenders in soon and getting the testing underway.
Also a new set of Golf Calipers with Pads are headed your way. Keep an eye out around Wednesday or so. Found some in the junkyard but they were way too rusted out so sprung for new ones.
Guvernor Eric Jones
Kinetic Motorworks
313 Kent Farm Road
Hamptead, NH 03841
1-603-329-6083
www.kineticmotorworks.com
Edited 1 time(s). Last edit at 04/14/2013 06:25PM by kinetic.
Josh Wimpey
Josh Wimpey
Sneak the Golf
April 17, 2013 12:48PM
Might as well use the mk4 caliper --- it is fully interchangeable with the mk1, mk2, and mk3 calipers but is half the weight and has a much superior parking brake mechanism.
Same piston, same pads, Aluminium rather than iron, and mounts to any of the carrier 'frames'
One. Class -- 2WD
www.quantumrallysport.com
April 19, 2013 09:03PM
OK boys, the calipers that Eric the Guv sent arrived, looks easy, the question is this. The easiest way to hand the caliper is off a 4 bolt flange behind where the stub axle bolts on.....but that moves the entire assembly out by the thickness of the spacer which I think should be minimum 10-11mm thick...
Then since we're throwing a disc OVER the front of the new hub aka the former drum, there's the face thickness of the disc...another 8-10mm..
Can somebody run out and look at the distance from the OUTSIDE of the tire to the fender opening and see if there's 3/4" or so of room?
(I'd love to find a nice 280mm disc that has a 1" deeper hat but....moody smiley )
RALLYRS
Mike Ball
Nope...I wish...RWD 2 Door Jeep XJ 4.0 5-spd Dirt-o-cross car(we have no grass!)2.3 ZX3 rallyx car(sold)
April 20, 2013 03:30PM
I threw on a gravel tire,because my 7x17 45mm offset Team dynamics and 225/45/17 Conti DWS street combo on my car appeared to be a "hell no"(duh).
Wheel is Braid 15x6 38mm offset 195/60/15 Firestone Winterforce....
Honestly hard to really see properly without pulling the rear spring and cycling(not going to happen today).
Fender gap down to tire on my car in back is about 3.5".
A straight edge against the tire/wheel assembly ends up almost on the outside of the fender....but we know these Foci/Mazda3 go pretty radical in negative camber as the wheel tucks......
However, 3/4" of an inch is quite a bit..Honestly I think thats pushing it....
I wish I had time to pull the spring and cycle,but if I do it would be later this week(maybe).
Can anyone else help?
Support your Local North American Rally Forum!!
While they are still around-and get the hell off Farsebook!!
We still have Specialstage & RallyAnarchy.
Post up Here:
https://rallyanarchy.com/phorum/posting.php
and here:
https://www.specialstage.com/forums/forum.php
April 20, 2013 05:46PM
Yeah sounds rough but that ET is already a whole bunch more -------> outwards than the ET 49 that Fucci come with...
Thanks for looking, let's hope somebody wif ordinary wheels speaks up.
ChrisKobi
Chris Kobayashi
2000 ford focus zx3
April 20, 2013 05:54PM
I can take a look tomorrow, I have steelies on mine with dmacks on em.
April 21, 2013 08:13AM
Will ordinary wheels work with coilovers?
ChrisKobi
Chris Kobayashi
2000 ford focus zx3
April 21, 2013 08:23PM
I've got 1.5 inches from the outside of the wheel to the wheel well.
April 21, 2013 08:54PM
ChrisKobi
OK thanks Chris.
kinetic
Guvernor Eric Jones
Subaru + Ford
April 22, 2013 09:43AM
I have 1.5" as well with stock focus wheels.... whatever these bad boys are....
Guvernor Eric Jones
Kinetic Motorworks
313 Kent Farm Road
Hamptead, NH 03841
1-603-329-6083
open | download - IMG_4496.jpg (138.4 KB)
ChrisKobi
Chris Kobayashi
2000 ford focus zx3
April 28, 2013 03:20PM
John,
So for the springs I just need to order 4 of the 14" #150 springs?
Also.. What are some recommended brands?
Kobi
Edited 1 time(s). Last edit at 04/28/2013 03:25PM by ChrisKobi.
April 28, 2013 04:18PM
ChrisKobi
John,
Kobi
I'll order springs today. Fronts gonna be 250
Rears 150 or 175.
Max needs some for the rear of his Wabbit and possibly for the fronts as well and a couple of others need too so I'll put the order in.
ChrisKobi
Chris Kobayashi
2000 ford focus zx3
April 28, 2013 04:21PM
ChrisKobi
John,
Kobi
Rears 150 or 175.
Excellent! I won't order them then.
Thank you!
