Duratec, yo Dave Coleman
August 04, 2009 02:48PM
Hey Dave can you dig up some confirmed basic numbers---like deck height on the 2,0; the 2,3; and the new 2,5 Duratec or whatever Mazdog calls them??
Gotta start collecting dims for a project.
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Re: Duratec, yo Dave Coleman
August 04, 2009 03:28PM
Hey John,
The Ford Racing catalog has all the dimensions except the new 2.5L motor. Not sure how this will post into a forum is. If you want to check out the catalog look at page 233 of the PDF file you can get at www.fordracingparts.com
ENGTH DISPLACEMENT Y EARS BORE STROKE SPACING DIA. DIA. (MEAN) DECK HEIGHT PISTON COMP HT
2.0L I-4 Duratec 2005-TBD 3.445 3.272 3.780 2.047 1.850 5.758 8.540 1.122
2.3L I-4 Duratec 2001-07 3.445 3.701 3.780 2.047 1.968 6.094 9.094 1.122
DJackson
Dawud Jackson
Watching from the sidelines
August 04, 2009 03:58PM
http://www.fordracingparts.com/download/charts/217.pdf
http://www.fordracingparts.com/download/catalogs/2009-pp.pdf
Or starting on page 223 of PDF reader.
Name: Dawud Jackson (DJ)
Occupation: Computer dude.
August 04, 2009 05:10PM
Andrew_Frick Wrote:
> Hey John,
Thanks---most of those are on file (in real numbers, too [grumble] not fuckin fractions of some fawkin ficticuous king's thumb!!! [/grumble]
But it is the 2.5 deck hgt and main journal we'ze most curiouser abouts.
Andrew_Frick
Andrew Frick
August 05, 2009 07:32AM
Why the 2.5 and not the 2.0 or 2.3L? I would think the 2.5L is going to be pricey to come by right now compared to the other two. And the power increase might be nominal since you will likely not be able to spin it as fast.
August 05, 2009 09:06AM
For the same reason I used a 2,3 block with a 2,0 crank last time I did a Duratec.
Same reason I used a 2,6 Mitsu and a 2,0 Mistu crank.
2,5 Duratec BLOCK is bored to 89mm and is reputed to be approx 19mm TALLER
(I build good motors, been building good internal designs for over 20 years. So I always check the available stock parts then select the individual parts to tailor a build. A motor with sucj a nice flowing head asks for a bottom end that can work with it. The bigger 89mm bore---to start with-- is a plus.
The taller deck height means there's a good chance I can do rods with longer c-c for a mo better rod/ stroke ratio using either a 2,3 or 2,0 STEEL crank.
This is for a FAST ROAD CAR project.
For a rally project say into a good rwd platform like oh I dunno a Xratty, I'd say "Fuckit shove in a Mazda steel crank, own import rods in a Pickup block and call it good."
We all know that 230bhp is more than enough in a 2wd car on gravel.
Jay
Jay Woodward
'90 Mazdog Frankenprotege
Jay
August 05, 2009 10:30AM
Me I wanna find out what the bellhousing bolt pattern on that there 2.3 lump looks like. It'd be kinda fun to have a truly competitive open light car, as opposed to an obsolete open car...
Jay Woodward
Snohomish, WA
Chronologically, 46...
Andrew_Frick
Andrew Frick
August 05, 2009 01:22PM
Jay what transmission are you bolting it to? I know that Lurch create a cad drawing of the 2.3L that he used when he bolted his xtrac up to the Mazda one.
August 05, 2009 07:06PM
> Mazda one.
Toyota Celica All-Trac, only about 2.5 times the size of the Maz-dog and3 times as complex.
He's not goig to blow it up, its one stout thang!
Jay
Jay Woodward
Jay
August 06, 2009 07:33AM
Yep, that's the one. I'd love to see Lurch's cad artwork on this thang.
And that damn gearbox better not blow the hell up dammit....
Jay Woodward
Snohomish, WA
August 06, 2009 10:51AM
> dammit....
Jay CHECK CAREFULLY all the possible oil quantities and QUALITIES and find all the fill holes!!!
That fucker is STOUT, but there's like 3-4 drains and who knows how many fillers.
Only thing that will kill that is NO OIL.
Jay, you find a decent cooler to plumb in?
Got some drive axles sorted?
> Jay Woodward
> Snohomish, WA
> Chronologically, 40...
Jay
Jay Woodward
Jay
August 06, 2009 07:14PM
Drive axles are a non issue, they'll talk to my hubs without mods. Gotta find an alltrac rear shaft though and maybe shorten it. Got a ways to go before I gotta worry about that however... I could use the cooler that's in the car but think I'll upgrade.
Jay Woodward
Snohomish, WA
Tony Whitlow
Michael Anthony Whitlow
XR4ti
August 06, 2009 09:00PM
Any help Dave would be great.
I am with JV on wanting to build a MZR / duartec project.
Where will this car lead me?
August 09, 2009 03:49PM
I have a 2.3 and would like to know more about building it for turbo because it
was a mazda 3 NA motor and i have a camaro tranny calling for it but I'm worried
because of cams and all that stuff steel crank what piston and all the jazz.
eyesoreracing
Dave Coleman
Mazda3, SE-R Spec-V, 510
August 25, 2009 01:20AM
Sorry guys, I just noticed this thread. I'll check the 2.5 MZR dimensions tomorrow.
Meanwhile, fun fact on the 2.5: bigger ports!
On the bellhousing pattern, all the MZR/Duratecs have the same pattern, so Lurch's data should do the trick.
JVL, is this an FF or FR project? Trying to look retro too, or just going fast?
-Dave
