What you describe is popular also and I'm absolutely not arguing with you but the A pillar support doesn't really transfer energy into the 1/2 lateral. The A pillar support mainly comes into play when the roof bars come down during a roll over impact. It is an opposite load path from what most people picture. The 1/2 lateral transfers energy into the A pillar support. Think of it as a last resort as the roof collapses. Triangulating the opening like you describe is fine and in fact we allow the A pillar support to be down a bit further for egress if done properly. It is ok for a cage to deflect and bend. It must protect the occupants, no one cares if the cage doesn't survive. Energy is absorbed by stuff bending, sheet metal and tubes. Energy not absorbed or deflected by crush zones is then transfered into the occupants. Years ago at an eastern short track they lost a couple drivers in a short period of time and studies showed it was because the cars were too tough. They guys would hit the wall and died from internal injuries...soft tissue and organ damage from the impact. No external injuries. Richard Petty pioneered a bit of this with NASCAR by making the suspension bits up front a bit weaker to fold up when heavily impacted. Old racing seats used to wrap around the rib cage only. Heart and spinal injuries happened a lot from side impacts. then someone figured out to spread that energy into the shoulder area also. Seats were redesigned and now seem a wonder of engineering techiniques and materials. Anyhow, people tend to focus too much on worrying about cage deflection or a bar bending. If the cage prevents or minimizes injury that otherwise would have likely happened it did the job. It is not a crime to have to replace a few bars or even the car. |
Ckgtimk2 Corey Kline Infallible Moderator Location: Lancaster, PA Join Date: 11/22/2011 Age: Settling Down Posts: 103 Rally Car: Used and abused Mk2 GTI |
Question.
From the NASA rule book... 3.8.7.1 Shoulder Belts Reinforcement Bar The transversal reinforcement shall be a tube measuring at least 1.5 inch x .120 inch or 1.6 inch x .095 inch, made from cold drawn seamless carbon steel. It is recommended that the bar be as close as possible to the seats. Is this the only place CDS needs to be used in the cage? Is there a reason DOM cannot be used? |
DOM is fine. Its just an oversight in the book. Blame Anders I've never seen 1.6 as a commercial tubing size either. NHRA requires 1.65 for their stuff. |
alosix Jason Powers Super Moderator Location: Lyons, CO Join Date: 08/02/2011 Age: Midlife Crisis Posts: 326 Rally Car: 02 WRX, still to quiet, but it finished a rally |
Largely its a look. DTM wannabes purposely miss the A and B pillars by miles and then connect with these punched plates full of holes, then the next guy misses by a mile and a 1/4 and more gussets. And on and on. Maybe somebody could exercise some care with the fit around any of the large holes in the bodyshell and just use discreet tabs.... Like most rally builders do. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
No doubt.. I'd like to be able to still use the car for grass o cross. So being able to see cones could be handy. Sounds reasonable. Given the thing gauge steel used there really isn't any meaningful weight savings (steering clear of McDonalds is more effective). Not really enough bends in the sheet to make it very strong either. |
While I reckon sometimes that's probably true, it's not always the case. I hardly ever use tabs because I take the time to get a good enough fit that I can just stitch weld the tube to the A-pillar or B-pillar or whatever. However, there are some cases where that's not practical or possible. On Dave Hintz's BMW, for example, to be able to do that would have required tilting the main hoop at an angle and mounting the feet in a non ideal spot. Also, it would not have allowed enough room for the seat to go back. The answer was to make a plate to tie in the main hoop and span the small gap. The dimpled hole are not for decoration, they add quite a bit of stiffness to the plate. Also, because I'm a cheap bastard I don't have any fancy dimpling tools. I just use some old half inch drive sockets and a piece of rollcage tubing held in a vice. And a hammer. |
Don't lie to us. We know you use the sledge side of a really big axe. |
What thickness plate are you using for that sort of setup? Guessing thicker than the 18 ga we were talking about for gussets.
The main hoop on a 4 Door GD bodied WRX is kinda in no man's land with respect to tying it to something. I suspect you could plate it to the rear door opening if needed. I've found a guy making the dies 'cheap' here: http://www.pirate4x4.com/forum/showthread.php?t=871560 Trying to figure out what sizes to grab though. |
Only when I can't find my claw hammer. |
14 ga for rollcage taco gussets and 16 or 14 ga plates to the body like I pictured. Something big like you would need for a 4 door Subaru I would go thicker or clamshell it from both side with thinner. |
A1337STI Alex Rademacher Senior Moderator Location: Reno,nv Join Date: 09/10/2007 Age: Midlife Crisis Posts: 686 Rally Car: 93 GC with an 01 RS swap! |
the roll cage in Betsy blocks the view a little bit. but i don't think it really affects me in rally cross. just don't go with too small of a steering wheel |
