Lets say I wanted to build a car...
Posted by BobOfTheFuture
BobOfTheFuture
Rob
None, anymore.
Re: Lets say I wanted to build a car...
February 23, 2012 11:04PM
Well in that case, stop following me... I don't know what the hell I am doing.
Im making it up as I go on... the fact that this hasn't bit me in the ass just says to me I haven't gotten very far yet. grinning smiley
Enablers, All of you.
Edited 1 time(s). Last edit at 02/23/2012 11:04PM by BobOfTheFuture.
BobOfTheFuture
Rob
None, anymore.
February 23, 2012 11:13PM
Speaking of, I got to figure out what to do next weekend...
Ive got to continue with the harness, repair what I fucked up. And not sure what else.
pist'n broke
kevin zidkovich
February 23, 2012 11:41PM
we can all learn from each other's mistakes. im sure im gonna make a few too
what could go wrong?
BobOfTheFuture
Rob
None, anymore.
February 27, 2012 10:42PM
So, Still messing with the wiring on the body harness... Fixed the wires I wasnt supposed to cut.
Just as I was finishing up it became apparent that the alternator was not charging. I got some time tonight and read up the manual, and realized that Ive got the gauge cluster disconnected.
The battery light, when lighting up during start up is used, like most cars, to excite the fields on the alt. Thats gotta be it...
Tommorrow I get to go find out if I'm right.
March 01, 2012 06:33PM
And the specific resistance in the light bulb is designed in as part of the start-up field excitation. Keep the same bulb.....or baypass and tyr some power resistors of different ohmages.
BobOfTheFuture
Rob
None, anymore.
March 02, 2012 01:12AM
I meant to have another update on my last day of last weekend but ive been too nailed at work and just coming home zonked to put any thought into it, but here goes...
First off, really? I figured it was just power. Im keeping the cluster for the time being, and attacking the dash wiring comes later. I got the car basically together again and the lightbulb was the reason for the alt issue so thats nice. Ive got most of the things i want working, working and the rear body harness is now in some split tubing and simplified so i'd call that a win.
Shitty pictures to follow, when im home.
Here we go:
Had to remove the cluster from its usual spot to get to the driver door wiring:
A bunch of the Junk i pulled out- useless wiring, electric window regulators
Last glamour shot before I left for the day:
I wrote all of this, While on break at work here:
Edited 3 time(s). Last edit at 03/02/2012 10:25AM by BobOfTheFuture.
March 02, 2012 12:39PM
hee hee that's about what the inside of my car looks like, but with less seats. At least i'm not in wiring hell alone.
BobOfTheFuture
Rob
None, anymore.
March 02, 2012 06:04PM
Haha, That pic has the seats freshly back in, they were out for a good 3 weeks. I just put em back in because I like to throw it together and drive it around every while, keeps the interest up and reminds me of shite I gotta fix thumbs up
Hey man, If you are going through wiring hell... Keep going. (regards to Winston)
Edited 1 time(s). Last edit at 03/03/2012 08:50PM by BobOfTheFuture.
March 03, 2012 07:29PM
I need a day of uninterrupted time to get it done. seems like everytime I get a process going something comes up and I have to figure out where I left off all over
BobOfTheFuture
Rob
None, anymore.
March 03, 2012 08:51PM
Absolutely, This is an issue for me too. This is why I walk around with a roll of that blue tape and a marker. I leave notes everywhere I feel I have to. My biggest issue here is the legibility of my handwriting grinning smiley
Edited 1 time(s). Last edit at 03/03/2012 08:54PM by BobOfTheFuture.
BobOfTheFuture
Rob
None, anymore.
March 19, 2012 04:08PM
Just an update: no updates for a while.
Fevers, surgery, stuffed full of gauze, recovery and bedridden for a while. Good way to spend the good part of spring...
March 19, 2012 05:38PM
BobOfTheFuture
Piccies or it didn't happen!
You should have seen the (used) tampons they had shoved up my nose when I got it rebuilt and ported and polished. Yeeeeeech!!!
BobOfTheFuture
Rob
None, anymore.
March 19, 2012 06:53PM
Haha, John, I do have pics. You would lose your lunch..es all the way back from last week.
If you really want, I can censor my butthole out of the pic and show you the new hole on the one cheek with the gauze stuffed in it grinning smiley
Goin back Weds to get it all pulled out of the abcess and getting closed up.
PnP: I laughed.
Too much info? This is anarchy right? thumbs up smiley
March 19, 2012 07:40PM
BobOfTheFuture
PnP: I laughed.
Hard to gross me out. I've seen yellow, green and black stinky goo oozing out of different holes in a charred hunk-o-meat that once was my leg. Stunk sumpin horrible, and i could see it---4 -12 times a day when they changed the bandages... Vile vile bad infection when you burn the meat to a literal crisp...
March 19, 2012 07:58PM
BobOfTheFuture
PnP: I laughed.
Ewwwww, but seems like an appropriate place to put this:
