Re: Another RWD motor option, if you can make it fit. smiling smiley
September 05, 2018 12:01AM
Interesting. What about the people bolting EJ transmissions up to FB engines so they can get dual range whatever-the-hell-they-came-in transmissions for the Crosstreks?
The bolt pattern looks so close I can't see how it is different. Still has a rudimentary pocket over the left side for the old starter position. The Frisbee twins even still have those two megalong studs on the bottom.
Well, we'll find out sooner or later. After I'm done digesting the financial mess the RX-7 and the Volvo have done to me this spring, I'm going to buy one to play with for a bit. Worst case, I sell it off, or find a cheap FB25.
Edited 2 time(s). Last edit at 09/05/2018 12:03AM by Pete.
Philippe Bellefleur
same as above
September 05, 2018 05:12PM
Aisin 6 speeds are weak, they're unreliable with a renesis in front so I wouldn't even try with anything more powerful, even less in a racecar. there is a reason Mazda made their own transmission for the S2 RX-8 & NC Miata.
January 23, 2022 07:37AM
How it started.
How it's going...
March 13, 2022 09:10AM
March 27, 2022 07:28AM
Probably not the easiest way to hang the driveshaft center bearing, but it made sense at the time ("the time" involved lots of stand and stare with Sobieski, Red Bull, and American Spirits in play. Better living through chemistry!)
Now the shifter and driveshaft work harmoniously with the rest of the vehicle. And it drives the rear wheels!
As soon as I put in the halfshafts, anyway... which comes before making the exhaust but after making the rear strut towers, but somehow I have to do them in the other order.
Edited 1 time(s). Last edit at 03/27/2022 07:31AM by Pete.
Mad Matt F
Matt Follett
March 29, 2022 08:31AM
This is very cool... winking smiley
Intent? Gravel flogger???
March 29, 2022 08:18PM
Mad Matt F
March 29, 2022 08:32PM
Stressing over making strut towers right now. I expect this car to be able to hit things sideways or land from six feet up and not collapse.
The Mini inner fender and such is made out of like 26 gauge tinfoil. It's gonna be tied into the cage but I don't quite trust that enough. Thinking that the inner fender will have to be doubled up before the strut tower gets made.
Edited 1 time(s). Last edit at 03/29/2022 08:33PM by Pete.
Mad Matt F
Matt Follett
March 30, 2022 11:47AM
Mad Matt F
Groovy babay....
April 10, 2022 11:51PM
Also, Bilstein HDs for an A2 Golf bolt up to Subaru uprights and the rally tires clear.
Mad Matt F
Matt Follett
April 11, 2022 03:51PM
Wait...
Wait...
Wait...
This is AWD? Or you are just using subie fronts cause you have them and no shafts... ?
April 11, 2022 04:48PM
Yep. Or rather it is RWD and FWD at the same time. Complete Subaru drivetrain and suspension.
Mad Matt F
Matt Follett
April 19, 2022 10:46AM
giggly giggly... winking smiley
May 07, 2022 08:20PM
Slowly making progress...
Don't think I will have it ready by the 15th eye rolling smiley But still shooting for ASAP because there are some kickass rallycrosses in DC region and, pending further info, we may run it at some rallysprints held on the same site.
Mad Matt F
Matt Follett
May 09, 2022 08:33AM
That's an evening and a 6 pack away from being done! drinking smiley
