Cosworth Paulinho Ferreira Junior Moderator Location: Charlotte, NC Join Date: 03/15/2007 Age: Midlife Crisis Posts: 721 Rally Car: Honda Civic |
You already fucked it up by deleting the descriptions. Oh never mind you added them to the bottom where you included the merkorrible specs. You need to change the motion ratio's, that .7 is no bueno, your front is something like . Front should be around .95/.98 |
WTF. Musta hit Cut instead of Copy. I actually fixed a few things that other people had screwed up, like typing in the in/lbs into N/mm on a few columns. Motion ratio is the (distance traveled at spring divided by distance traveled at wheel) squared? Still, what does it mean? Ya can't share without trying to educate a few heathens. Grant Hughes |
Same here. The closest I can come is by double diphthong-izing all the vowels into something like "Mair-KOOOOOOR " but stretch out 5 times longer than reasonable like Maaaaaaaaaaaaaaaaiiiiiiiiiiirrrr KOOOOOOOR Poking fun at the horrible 'Meikun habit of stretching vowels which in other languages are usually single short discreet sounds not diphthongs--unless they are doubled or vowel pairs. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
You're getting ahead of yourself. Motion ratio is just that: the ratio of spring compression to wheel movement. The squaring comes in when you are calculating the wheel-rate from the actual spring-rate. WR = SR * MR^2 |
krisdahl Kris Dahl Ultra Moderator Location: Issaquah, WA Join Date: 02/13/2006 Age: Midlife Crisis Posts: 282 Rally Car: Integra, Civic |
shiza Dan Norkus Junior Moderator Location: Goldsboro, NC Join Date: 01/10/2010 Age: Midlife Crisis Posts: 290 Rally Car: 94 Integra |
My Integra came with the Hotbits setup on it. I know the fronts had to be rebuilt after the 2nd event due to an "internal defect" from the manufacturer. I've driven it a good amount since they've been rebuilt but haven't seen an actual stage yet. Idaho gravel roads are smooth enough for stock suspension so they aren't much of a test. I have done a couple tarmac hill climbs on them without changing springs or installing a front sway bar. They handle like crap on tarmac with the gravel setup haha. The adjustability is nice because the way they were setup when I got it. The rear was way too stiff. I was having trouble keeping it in a straight line on gravel. A few clicks out of the rear and it handles right for me. For the one rallyx I did I tightened the back up again and it handles great for the low speed tight stuff.
What do the hotbits cost anyway? |
mke723 Mike Lindenfelser Junior Moderator Location: Minnesnowta Join Date: 10/17/2012 Age: Midlife Crisis Posts: 154 Rally Car: 1995 Impreza L |
PeteNaz Peter Nazarewycz Mod Moderator Location: Alberta, Canada Join Date: 08/23/2012 Age: Settling Down Posts: 76 Rally Car: 96 Honda Civic Hatch |
Hey ya I got a quote from them with shipping to my door for. one way adjustable I believe
"Honda EK chassis. DT1 Canister rally kit $2167 including shipping. GST extra. All 4 canister monotube dampers, main and helper springs, boots and bumpstops." One more Rallycross on Ghost lake tomorrow that I'm so excited for! getting faster and faster everytime ![]() Then Trail of the GNU next saturday ![]() I'm always posting on Instagram...follow me! PeteNaz Instagram My Build ![]() Edited 1 time(s). Last edit at 03/15/2013 02:56PM by PeteNaz. |
brianosaurus Brian Gottlieb Infallible Moderator Location: Portland, OR Join Date: 05/25/2007 Age: Possibly Wise Posts: 8 Rally Car: 1988 Toyota FX-16 GTS |
I didn't use Hotbits on my Honda, but I had them for a few years on my Toyota FX-16s. I was very happy with them.
Before the Hotbits I was using KYB GR-2 inserts, and replacing a set every rally (I even had a GR-2 blow out at a single rallycross). I sent the set out for servicing once by Feal suspension in California, with probably 10 events before servicing and at least another 10 or so after. I have heard Subaru drivers tell me the same Hotbits horror stories as John relayed, so maybe we're just lucky that our 2WDs are light weight. If you are looking for another alternative to Hotbits, I know Primitive Racing has a set of TEINs for an EK that is around that same price range. I used a set of the TEINs last year on Dojo, and liked them. Springs are 65kg/cm front and 35 rear (pretty sure I'm recalling correctly), dampers are adjustable rebound and compression, with external reservoir. I had to replace a bushing in the lower rear control arms since the EK bushing is narrower than on the EF, but they fit and work nicely. We just put my TEINs on Cody Crane's CRX. After the Oregon Trail Rally he'll be able to tell you how they feel compared to 7 year old KYB AGXs. ![]() |
Dude just go get some Bilstein HD's and I'll give you the valving stack to make them work. These suspensions don't stress the dampers like McPh struts. That's why the hotbits wont puke the guts on civics. But those dyno's from hotbits showed the lines all over the place with the clicker changes. A lot of cross talk from compression to rebound, and it changes the shape of the nose on some of them too. Plus that damping strategy seems a bit strange, definitely not very rally like.
Another nugget of Gold John! First Rally: 2001 Driver (7), Co-Driver (44) Drivers (16) Clerk (10), Official (7), Volunteer (4) Cars Built (1), Engines Built (0) Cages Built (0) Last Updated, January 4, 2015 ![]()
Out of curiosity is that straight from them or through Shawn at RallySport.ca? (local rally guy and supplier) Seems to me the guys in Subarus would kill HotBits regularly but hat was the first version and I think they've dealt with the issue. Eric Grochowski has run the same HotBits in his golf since 2006 and has done most of teh national championship in each of those years, including the rough eastern events, without any serious, non-induced, issues. There are a few people locally who have run JVAB, talk to them directly about their experiences if you're thinking of going that route. First Rally: 2001 Driver (7), Co-Driver (44) Drivers (16) Clerk (10), Official (7), Volunteer (4) Cars Built (1), Engines Built (0) Cages Built (0) Last Updated, January 4, 2015 ![]()
Edited 1 time(s). Last edit at 03/16/2013 01:00PM by Morison. |
