sidewaez Blake Lind Super Moderator Location: Hillsboro Oregon Join Date: 06/09/2009 Age: Midlife Crisis Posts: 233 Rally Car: orange AE86 |
brianosaurus Brian Gottlieb Super Moderator Location: Portland, OR Join Date: 05/25/2007 Age: Possibly Wise Posts: 8 Rally Car: 1988 Toyota FX-16 GTS |
PeteNaz Peter Nazarewycz Mega Moderator Location: Alberta, Canada Join Date: 08/23/2012 Age: Settling Down Posts: 76 Rally Car: 96 Honda Civic Hatch |
Hey Keith! that was direct from them when I was doing my research. I've bought a ton through Shawn so far, such a great guy. Its great to support the local scene. I'll talk to some folks about their setups, lots going around, I like the Tiens as well that have been mentioned And Paulino, I would probably take you up on grabbing that valving info. Would I just order billies then have them sent in, or talk to Bilstein directly before ordering? Is it possible to size spring lengths before I've bought the dampner? Or should I wait for them to come in then figure out what lengths? and Tenders and all that? I'm always posting on Instagram...follow me! PeteNaz Instagram My Build ![]() |
This was the SlideALLday event yesturday at Ghost Lake. lots to improve on! but I had a complete blast I had better runs that werent filmed or better turns but I know its cheesy cuting and pasting only the best ones into one run! On to Trail of the GNU on Saturday. Trail of the GNU I'm always posting on Instagram...follow me! PeteNaz Instagram My Build ![]() |
BillyElliot Billy Elliot Mann Senior Moderator Location: Royal Oak, MI Join Date: 08/11/2008 Age: Midlife Crisis Posts: 557 Rally Car: 1996 Honda Civic with VTEC YO! |
Just buy a Honda Civic 96-00 Bilstein HD damper because it's a 46mm piston. OEM piston size is some measy little one, so DO NOT GET DIRECT OEM REPLACEMENT or you'll get the 20 some mm piston. Don't fuck with getting longer shocks, get the OEM part replacement bilstein shocks. You'll have to pick up their coilover sleeve threaded collar and adjustment collars too. If you wanted to go with longer shocks you'd have to start modding the shock towers to do that. |
The damper bodies are grooved for some retaining rings to hold the sleeves. We welded some on there to make sure those things didn't fly off and dump the sleeve.
Peter, just get the HD Billes that Billy mentioned, they can be modified for extra length. There's a spacer on the shaft for the internal rebound stopper that is 40mm long. It can be modified to only 10mm and it will gain you about 2" of wheel travel, while at it you can add the nitrogen valves for easy serviceability and all the goodies. |
Would you suggest getting tenders as well with this setup or just worry about the spring for now? Is it the 2inch sleeves that go over the HD's or the 36mm? I'm guessing 2"? 2" 36mm What spring length are you running on your spare bilstein setup? I'm always posting on Instagram...follow me! PeteNaz Instagram My Build ![]() |
I'm not familiar with Honda suspension very much. With a strut application (vw, subi) the sleeves just slide over and sit on the bracket for the knuckle , if you're lazy. You can also weld on a ring at the bottom to hold the sleeve as well. The rear shocks will have grooves cut in them. These have a snap ring that supports the sleeve. Some have had issues with these popping out or breaking. The Allstar sleeves capture the snap ring pretty well. I haven't had any issues in 800+ mi of endurance racing + grass-o-cross + fun driving.
I have 12" springs on there. No need for tenders unless you chose stiff springs. |
Aaron Luptak Aaron Luptak Elite Moderator Location: SLC Join Date: 02/15/2008 Age: Midlife Crisis Posts: 776 Rally Car: Civic... |
Hondas are going to be the same snap ring setup on all four corners. I'll have to keep the Allstar stuff in mind - if you buy the sleeve and perch separately from summit (don't need the top mounts if you're using the stock upper mounting) you'd be looking at $31/corner - much better than the $70/corner for the Bilstein sleeves... ![]() ![]() http://www.utahrallygroup.com |
I run tenders on mine for gravel, but I don't think I've tried running them on my gravel springs with no tenders. I know I need the tenders for my tarmac springs because if I just put the spring in the car sits all lifted and now lower like I need it to be. I guess I could muck around with it some time once it gets warmer and see if I can run my gravel springs without a tender. But I'm guessing it will be like the snow rates I run no tender but put pre-load. But as I've mentioned before, my 300mm spring length for snow isn't long enough because I get a lot of spring binding (all the paint inside the spring is all flaking off from making contact). But if you're running with spring tenders, a 300mm spring works, which is what I use. Running no tender you'd be looking at a 350mm spring. How long do you have to get this all sorted out and pick your spring rates for your first gravel rally? It's a few days until spring and we just got snow in Michigan but once it gets warmer I could take a day and swap around springs and get some data for you to go on. Paul, you have any issues with spring binding on a 12"/300mm spring running no tenders? I don't see any with mine, but I'm not running with much pre-load because there's still room for the tender to compress before it binds. Edited 1 time(s). Last edit at 03/18/2013 11:31AM by BillyElliot. |
First event will be May 25th, the Cochrane rally. Which is the weekend that the Rocky Mountain Rally was originally held the last couple of years. And I believe its been muckkky but it can also have potential to be dryish.... So maybe some softer springs would do some good for this event. I wont worry about tarmac right now, but I'll make sure I have gavel and snow spec springs for the event... Keith, what do you think from any previous experience or talking to competitors at these events? I'm always posting on Instagram...follow me! PeteNaz Instagram My Build ![]() |
