mellow65 Oliver Klozoff Godlike Moderator Location: Oregon Join Date: 09/10/2008 Age: Midlife Crisis Posts: 480 Rally Car: Nada |
With the casual measuring you are correct on it being to wide. But once you sit it in there it shocking fits into this perfect little spot. The key I found was using the earlier 2.2 heads. They are pretty compact and the valve covers only cave half the head.
I tried some dohc heads but they were just to big. They got in the way of all sorts of things, oh like the frame and the steering. "Rally racing makes a heroin addiction look like a vague craving for something salty" |
Dayum, a few simple questions and you're acting all attacked. Using words like "defending". No you haven't been attacked, you've been asked in a normal curious way Why?
Asking why this versus why that is not attacking, this is not some punkk-ass pimple squeezer fan-boi forum where everybody is trying to establish their hierarchical niche position. Its just seems like an odd choice. And just for reference, the nice gearkit for T5 for any motor that makes any torque costs $380. has 2.95 first and some crazy overdrive like either 0.63 or 0.72. That first, very similar to some of the nicer Subie boxes and the Evo-bitchi boxes , allows a shorter axle ratio and gives a useful first gear that'll get you to 40-43mph, and a shorter 4th for more yank (ie quicker back up to whatever speed we chicken out at, once we backed off at say 96mph) In short: relax, we're just yakking.... (or tell us if anything other than "gee golly that's brilliant " is "an attack" you need to "defend yourself" against...) John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Pete, any more information on that mazda-subaru combination?
John, can you share a link for your $380 gear set for a T-5 or at least share what the other ratios are, just curious what you consider a good set of gear ratios? Matt, So you are basically limited to a NA Subaru config in your application? Or is there room for the turbo hardware should you decide that it is not enough power? |
KTurner Kevin Turner Senior Moderator Location: Newark, DE Join Date: 01/27/2006 Age: Midlife Crisis Posts: 364 Rally Car: 2wd Impreza... dude you should do an sti swap |
I run my 2.2 Impreza out of oil all the time. Check the dipstick every few oil changes. It's always dry so I add another quart. I don't check it again cause it's probably still dry but if I add too much it just drips more on the ground and smokes worse at stop lights.
Maybe when the engine is built so well you don't need all that stuff you mentioned John. I like the idea of a Subaru powered 4X4 Starlet for going four wheelin'. |
Andrew had real "just asking some questions", your first post included not only a negative toward the transmission choice but also the motor choice. Im pretty sure I didn't ask, hey find all the flaws of what I'm posting based on your opinions. You know what, maybe a duratec motor is better. Can you show me proof of that? Because I can show you plenty of cases of a Subaru motor being damn solid. With all the "short comings" you claim the Subaru motor to have, it's just shocking how well it lives it's life just plugging away. And john it's not so much that I fear criticism or everything I say has to be praised as being the best written words on the planet, but fuck, if it's not a Volvo, a t5, a duratec, or some long link suspension it must be utter shit. you have made it almost to the point on here that if I don't agree with everything you say you are going to flame the shit out of me. And the real sad part is it works like clockwork, we just come to expect it now. That being said, playing devils advocate is a good thing, but man you have a way of coming off as a sarcastic ass sometimes. And maybe you have no ill intentions with what you say, but if you haven't noticed yet, sarcasm doesn't translate via the Internet very well. And maybe I should pull my tampon out, but I know I'm not the only one that feels that way. "Rally racing makes a heroin addiction look like a vague craving for something salty" |
For the time being I'm limiting myself to NA power due to simplicity and cost. I can get my ej22 running and work out all the little things with out needing to worry about figuring out the turbo system at the same time. How ever where the motor will be placed it will still have the same fire wall clearance as a Subaru so it leaves that area on the passenger behind the motor as a perfect place to add a small turbo at some later date. You know when I can even think about running a turbo and the cost doesn't scare the shit out of me. I also am working out using a svx motor. Thats going to take some cutting though. "Rally racing makes a heroin addiction look like a vague craving for something salty" |
Doivi Clarkinen Banned Elite Moderator Location: the end of the universe Join Date: 02/12/2006 Age: Possibly Wise Posts: 1,432 Rally Car: 1980 Opel Ascona B |
Wow you guys may want to have that checked out. There seems to be something going around. Sorry you guys have such a bad taste for subarus, they really are great little motors. The 250k on my DD has to speak something. Can't say I could get that out of any ford with out a rebuild or two. "Rally racing makes a heroin addiction look like a vague craving for something salty" |
A1337STI Alex Rademacher Infallible Moderator Location: Reno,nv Join Date: 09/10/2007 Age: Midlife Crisis Posts: 686 Rally Car: 93 GC with an 01 RS swap! |
none of my subaru transmissions ever could go faster then 35mph in 1st.
96 AWD, 03 WRX, 05 STI, 98 RS, 93 FWD. actually most on stock gearing end at 30 my sti goes to 35, and 2nd takes you up to 55mph. some legacies got longer 2nds though ... here's my mph in gear/ rpm chart : http://www.car-videos.net/tools/speedrpm.asp?Car=Select&Num1=184&Num2=65&Num3=15&AxleRatio=4.11&Ratio1=3.545&Ratio2=2.11&Ratio3=1.448&Ratio4=1.088&Ratio5=0.780&Ratio6=&Ratio7=&Redline=6250&Increment=500&B1=Recalculate This idea / product is great enough to get real criticism. take it as a compliment if it was a bad idea / bad product no one would take the time/energy to chat about it, wonder why this, why not that... etc... |
You're doing a lot of comparing apples to oranges. And yes, I will call you out on comparing it to a Subaru transmission. Those Subie ratios are nothing to write home about (there are stock Subie trannies with better ratios). There are all kinds of other transmissions you could have chosen. Your size comparison is completely misleading. Remove the bellhousing and center diff from the Subie tranny so it's a direct comparison and you can see the Subie is much smaller (though probably also much weaker, don't know how strong Toyota transmissions are.) It is cool you made a rwd bellhousing for a Subaru though, and I suspect it wouldn't be too tough to make an adapter plate to use a T-5 or whatever with it. Still can't understand why you would want to put a Subaru engine in an RX-7 though... |
Subaru engines are great in Subarus, I just don't think highly enough of them to swap them into a car that already has a better engine (like an RX-7). I'm not a Subaru hater. I've worked with plenty of Subarus. I worked on the original prototype of the Subaru DOHC 16v engine (designed & built at WWU's VRI in Bellingham.) I wouldn't consider Subaru engines the most bulletproof thing when they are pushed for lots of power and raced hard. Just because a Subaru can last 200k plus miles putting around as a grocery getter (lots of car can do that) doesn't mean it will be so reliable when pushed to it's limits. A well built rotary on the other hand can easily last for ten years or more of racing with no problems. But whatever turns your crank. |
They're a lighter engine and they don't puke when you get the coolant temps over 210 or get a little dust in 'em. Sounds a hell of a lot better to me. I'm kinda tired of constantly rebuilding the things. |
jrally Jon Rood Mega Moderator Location: Phoenix, AZ Join Date: 10/19/2010 Age: Possibly Wise Posts: 154 Rally Car: '94 Escort GT (sold) |
This was developed for the crazy guys doing solid axle swaps on early Subarus that wanted a strong tranny with a proper transfercase option. (not racing, just wheelin) I think it's a very cool option, just would have trouble fitting a Subi engine between most other cars frame rails, I would think.
-Jon |
you are correct, there are some other ratios in stock form, i missed this one the first time around US Legacy Turbo GT MY05 ran 3.166 1.882 1.296 0.972 0.738 but that's the highest i can find from the states. there were some other JDM stuff that had a higher first, but probably not going to run across them here. the next highest 1st is 3.454 then 3.545. and actually it doesn't look like it, but the input shafts are lined up and if you took the tail housing away you wouldn't have a way of making it rwd. I'm comparing apples (subaru) to oranges(rwd) because i have to, there is no other oranges out there to compare it to. someone make the t5 bell housing, and I'll be the first to probably tell you the t5 will be better then the w58. until that point, all i can do is compare what is available.
i think we could debate a rotary being better then a subaru for ever, and I'll tell you right now, I'll never believe you. But my reasoning for the subaru motor is it's a very unstressed motor. I'm not going to pushing lot of power either. Just a stock little ej22. low compression, non interference motor. And the main reason is they are damn cheap. I'm not saying a rotary could not be made to be reliable, it's just going to take some money. I remember talking to Gene about costs of rotary work and how back in the day he would spend a few hundred dollars for his rebuilds. And that was having someone do the work. The 12a that was in my old rally car only dynoed at like the 130 range at the wheels, that was after $1200 spent for the motor, and COUNTLESS hours dyno tuning to get all they could out of it. So i have to say the a 150hp at the crank 12a was well over $2000. Sure more power could be made, but then you stress the motor even more. And if you can't keep them cool, you're pretty much effed. and you are right, there are many cars out there that could run 200k miles as a DD, but i'm betting a rx7 wouldn't be one of them.
from what i can find around, the 12a falls in at around 350lbs, where the ej22 is under 250lbs. and i appreciate someone that runs one talking about their short comings. I didn't have tons of time with one, but the piles and piles that i have read on them never shed them in a good light. "Rally racing makes a heroin addiction look like a vague craving for something salty" |
