Andrew_Frick Andrew Frick Mod Moderator Location: Greenville, SC Join Date: 05/18/2007 Age: Midlife Crisis Posts: 684 Rally Car: Rally Spec Ford Focus |
Since we are talking about power. Here is a Volvo option that fits John's criteria other than price. Ford has also just released a EC?U and wiring kit for it which takes all of the guess work out of the wiring. Should be good for a 100,000 miles.
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=22999 tech notes 252 Horsepower @ 5,500 RPM 270 lb. ft. of torque @ 3,000 RPM All-aluminum construction - about 55 pounds lighter than a comparable naturally aspirated V6 engine 9.3:1 compression ratio - Premium fuel recommended Ti-VCT Strategy Employs twin independent variable camshaft timing for optimized fuel economy, performance and emissions Borg-Warner Turbocharger with low-inertia rotor spins at speeds up to 195,000 rpm, producing up to 16 psi of boost Optimized design ensures that maximum torque is achieved at very low engine revs Peak torque available from 2,000 to 4,500 rpm Direct-Injection high-pressure fuel system Seven jets on each injector spray fuel directly into the combustion chamber Engine design has been optimized for maximum operating efficiency, with a focus on minimizing friction and other parasitic losses Low-friction coatings on the piston rings and highly polished surfaces on the tappets Engine Kit Includes: Starter Alternator Front accessory drive and belt Intercooler and air intake ducting Air Cleaner Assembly Manual Transmission flexplate/flywheel ECU and wiring for custom installs. http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=22998 |
Thomas Kimsey Thomas Kimsey Elite Moderator Location: Rochester, New Hampshire Join Date: 10/05/2013 Age: Settling Down Posts: 271 Rally Car: 1988 XRatty |
Considering this is the engine shipping in the current Focus ST, 16 psi is a very conservative number. Boost should peak at 21 psi and be about 18-19 psi constant. Suggested Retail Price $8,000.00, better start stuffing your piggy banks. |
MattWatson Matt Watson Mod Moderator Location: Calgary Join Date: 04/17/2013 Age: Midlife Crisis Posts: 151 Rally Car: Merkur |
At 9.2:1 Compression, putting it much higher would require some better fuel I personally think. I like how they say "Premium Fuel Recommended" if you didn't use it, they must have some amazing knock detection and boost cut. But maybe I am just stuck in the old saab days |
9.3:1 and it runs fine on the crappiest of fuels. Modern knock detection and engine control is a wonderful thing. The 21 psi comes with what Ford calls overboost. You are limited to 15 seconds of it in optimal conditions. |
Actually tyhe thread was supposed to be a real world based comparison limited by the examples given Ya know? When the master questioning the pupils and says "Given the following two examples....., compare and contrast" You aren't supposed to just free associate or start blabbering about 100 years of Snmall Block Chevys dominating or yakking abvout cheap mundane limp BMWs but rather keep to the example E36 M3 with 240 bhp... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I have the perfect motor for ya then. nice 1948 ford flathead. Nice 3 main bearing design, a whopping 120HP great flow characterisitcs and low center of gravity. Take that technology! |
Well we were hoping for a real life example for comparison this weekend but the rally gods intervened and the Volvo broke before the event. Really bad deal. Sadly the old stock engined BMW plugged along for another 2WD win, but the AWD guys were certainly on their game this weekend.
Jardevall couldn't source another turbo I was told, sucks. |
Drinking again so early? You have decades of real world examples, you obstinately choose to pretend the only thing that counts is what you see right in front of your nose... That little corner of the State isn't the whole world Gene...and that has always been your way... It's a shame Jardevall didn't have a spare in the truck... just imagine if he paid attention here and had a his turbos modded like this: Easy swap even when hot.... Whatever, why don't you call Karl and tell him to dump the Volvo motor and put in a small Block Chevy that have been dominating things for 50 years before they were made? Or why didn't you condescendingly tell Derik that that BMW is shit and HE needs a SBC to beat the Subies? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Nope you're stuck with the rate of burn and both you guys are stuck with 96mm which is a lot further than 87.5mm aboveor 79mm like the 1,6 Ecoboost.... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Well Mr. VanSlanderham, I rarely drink and never to excess. I don't have a problem with Derek, his car, his engine or his choice of suspension, nor do I have any issues with Carl Jardevall and his choices. Unlike you I am not my brothers keeper. Like all of the 300 plus unknown speccies that managed a weekend off I just like rally. More, varied cars the better.
Maybe should take a bath, brush your teeth, get a bus pass and find a real job that afforded a guy of your immense talents and knowledge a wage worthy of what you bring to the table. And you really should figure out a way to make the event, support and future sales in the business world might be considered the same as rear towers and JVAB suspenders in rally...common sense. |
Morison Banned Super Moderator Location: Calgary, AB Join Date: 03/27/2009 Age: Ancient Posts: 1,798 Rally Car: (ex)86 RX-7(built), (ex)2.5RS (bought) |
QFT Family first is right, but planning to fit in good business promotion on the occasions it comes to within an hour and a half of your doorstep isn't exactly forsaking the family for your business. (It's supporting your business which supports your family, presumably) But, it would have also meant a helpful approach to solving the problems at hand, and not 'that's why you shouldn't have done it that way' quipping from the sidelines. First Rally: 2001 Driver (7), Co-Driver (44) Drivers (16) Clerk (10), Official (7), Volunteer (4) Cars Built (1), Engines Built (0) Cages Built (0) Last Updated, January 4, 2015
LexusFman Yengi Lado Senior Moderator Location: Potsdam, NY Join Date: 03/13/2013 Age: Party Animal Posts: 236 Rally Car: I Ain't rich!!!! |
Thank you boys, I know you both manufacture a large variety of somewhat complex parts and all your suppliers have you on speed dial and are never weeks late with deliveries routinely and uexpectedly so you can relax about scheduling... i really should study more from guys like you 2 who have been manufacturing things for so long. I was thinking "How in the world could I justify taking even one day off when I have such a backlog of work from delays delays delays? Up at 0645 in bed at 0030----maybe I could zoom down for a few hours between 0100 and 0500... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I dunno Gene I was just asking because you seem to be getting increasingly irrational.. Small block Chevy dominating everything for 100 years? Was that humor that i didn't get? Calling me a liar in some thread? WTF is up with that? So when people suddenly become well crazy in some area, ya gotta wonder what's up.. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
