Re: Revamping the Rx7
June 18, 2012 05:19PM
Yeah, it's why I am trying to cram an early S4 intercooler (all aluminum!) in my Quantum instead of using the 5000 piece which is almost a bolt-in.
eyesoreracing
Dave Coleman
Mazda3, SE-R Spec-V, 510
June 18, 2012 05:48PM
Fuel pump needs to be contained in a leak proof case if inside the hatch area. I do not wish to have it tuck under the car. SOOO would it work if i just used a metal ammo can? They are metal, leak proof, etc. I dont see why it would work.
Also, could i use plastic ones instead?
I don't suppose anyone bothers to define leak proof, do they? If my pump outlet starts leaking and filling up my leak-proof pump case, eventually I have a case full of fuel pressurized to >43 psi. I'd prefer something designed to leak to the outside of the car to ensure it can't leak to the inside.
June 18, 2012 06:01PM
well nothing is really perfect, but i think my idea would work just fine. The other option would be the spare tire well, but that requires more work. I already have said ammo box. And thats just bolts in.
June 18, 2012 06:03PM
also intercooler wise, i suppose i would go with another option then.
BUT fate has intervened. Rally America said no to my Group 5 waiver, so the turbo is coming off for now anyway it seems.
horrah 110hp
June 18, 2012 06:10PM
horrah 110hp
Didya tell them you weren't just some co-driver but were in fact a has-been-extrme skier? or did backflips on rad-ass tricycles while wearing rain gear and swim finns? Do you email/call or did you have your media management agent negotiate a deal with them?
And you say smoke da spliff a lot and you're rich?
If you did, I don't see why the would refuse?confused smiley
mellow65
Oliver Klozoff
Nada
June 18, 2012 06:18PM
horrah 110hp
Dont let it keep you back, Adam runs about that kind of power in his corolla.
Also some old timers once said, (gene I think actually, and other too) learn to go fast in a slow car.
June 18, 2012 06:45PM
http://www.solomiata.com/cams.html
June 18, 2012 07:49PM
mellow65
But there is a huge presumption in that statement and that is that somebody doesn't know how to drive.
How do we know everybody doesn't know how to drive and therefore they need to learn?
And ultimately, sooner of later, its just the way things go that people will one day need to learn how to learn to deal with a faster (stronger engine and shorter gearing) car.
Sooner.
Or later.
Why not learn restraint---the problem most amateurs have---sooner?
mellow65
Oliver Klozoff
Nada
June 18, 2012 10:34PM
But who right out of the box knows how to rally? Sure we have slid on gravel here and there and played on dirt in someones back yard. But I don't know many that come to rally with some vast dirt driving knowledge.
And because restraint isn't something you are thinking about in the middle of stage, it's all go go go when you are a newbie, restraint can be forced by an underpowered car. Then you can learn what the car is going to do when you do this or that rather then learning that along with restraint.
As we learn in our newbie meetings, a rally driver loses all but 3 brain cells when he sits in a car, one each for turning, braking and the gas, no spares for restraint. smiling smiley
June 19, 2012 12:06PM
I had an all metal urs4 cooler but have no idea where it went. The 5k IC isn't the worst thing in the world. it's small and with some fabbed endtanks would work. I was offering it for free anyways, and free don't hurt much.
Bummer on the license, why don't you run a couple of the non RA events, you do have quite a few options.
June 19, 2012 12:15PM
Elaborate as to which ones?
Obviously, Idaho.
Mt. Hood is still NASA?
NNR, Mendocino, Seed 9 are RA. (As are Oregon Trail and Oly, obviously)
Does canadia allow nervous novices in tarbo cars?
June 19, 2012 12:27PM
From what I've seen, a lot of beginners still need to learn restraint even when driving poorly geared, low power cars.
June 19, 2012 12:40PM
Obviously, Idaho.
Does Canadia allow nervous novices in tarbo cars?
Yeah but it's like a grisly charnelhouse. Bodies shredded, oceans of blood but there's no freedom in Canada and the Government controls everything so all the long lists of people blown into hamburger meat at every event is suppressed.
It's all been gone over dozens of times, take a stock little 1.6 BP or whatever, but any turbo on it and it's end like at 1:02-1:03 and 4:27 on
<object width="420" height="315"><param name="movie" value="
?version=3&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=
That was taken at rally events where because there were little tiny turbos on otherwise stock cars it was a slaughter, and it was smuggled out of Canada.
June 19, 2012 12:57PM
At present, and in the foreseeable future, there are no restrictions on new drivers at CARS events. It is, however, a somewhat regular topic of discussion. (but don't confuse regular with frequent.)
June 19, 2012 02:35PM
Obviously, Idaho.
I was under the impression that nevada was independent like idaho, however I just checked the sups and you are right.
Prescott and gorman, and high desert trails were the other ones I was thinking of.
