Re: Open Light Subaru build
March 16, 2012 03:19AM
those WRC parts look intense, (expensive)
March 16, 2012 07:53AM
What about running slighty longer bumpstops to slow(?) or limit full compression travel?
SgtRauksauff
Jorden
March 16, 2012 12:29PM
is that Volvo's attempt to make a Porsche 911 look-alike?
Jorden R. Kleier
Baraboo, Wisconsin, USA
1990 Mazdog Protege 4WD
1973
tdrrally
edward mucklow
August 08, 2012 02:05PM
i picked up a pair of 95 imprezi coupes
one is rusted to death a 2.2 awd auto
this one is a solid 1.8 5spd awd
both are red
August 08, 2012 04:50PM
is that the good one? sounds like you should swap the 2.2 to the good car cause it's not nearly as slow as the 1.8.
tdrrally
edward mucklow
August 08, 2012 06:26PM
here is the parts car
the 1.8 runs great but it needs an axle
i may run replace the axle and drive it before swapping engines
i do have a low milage 2.2 in my legacy complete with all sort of new parts
August 08, 2012 06:34PM
Depending on generations, you can swap the 2.2 bottom end and use the 1.8 intake manifold for a quick and easy swap with no wiring or otherwise since everything is still 1.8.
tdrrally
edward mucklow
August 08, 2012 06:50PM
the legacy is a 90
with a 93 engine i had to change the intake for that swap so whats once more
August 10, 2012 03:03PM
if you are going to swap at least get all the improvement that you can. It's easy to swap the engine harness, just have to swap the plug for the throttle or IAC (secret: the pins should be the same, just have to swap the plastic portion of the plug). and the throttle body coolant lines are different, might have to carry over an emissions valve, not hard. we're not talking about a lot of power but look how small the 1.8 throttle body is compared to the 2.2 it has to make some difference.
tdrrally
edward mucklow
August 10, 2012 03:45PM
looks like the 2.2 tb will bolt to the 1.8 manifold
i plan to drive it around with the 1.8 for the time being
August 10, 2012 05:01PM
tdrrally
Hang onto your hat, them 1.8s are beasts!
Don't forget the Family Sized bottle of industrial strength No-Doz.
tdrrally
edward mucklow
August 11, 2012 10:22AM
lol
its a beast for sure sir!!
it is easy on fuel
modernbeat
Jason McDaniel
September 25, 2012 06:55PM
Ok, so it's not really build related, but Brianne bought another coupe. This one was a FWD auto with completely blown rear struts.
Why suspension is important.
Jason McDaniel
September 25, 2012 07:25PM
modernbeat
Brianne just jumped way up on my Christmas Card List...
Too hilarious.
<object width="640" height="360"><param name="movie" value="
?version=3&amp;hl=en_US&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
Edited 1 time(s). Last edit at 09/25/2012 07:29PM by john vanlandingham.
September 25, 2012 07:35PM
modernbeat
Totally related! Now she needs to buy one with struts without springs and show the car dragging its tail with nothing to hold it up!
