Revamping the Rx7
Posted by Gravity Fed
Re: Revamping the Rx7
March 04, 2013 10:47PM
sounds much cheaper than buying the moiser axles...
i need to call Re Speed about that rear brake stuffs.
re Speed?
I haz ciggies, call.
March 17, 2013 12:01AM
helper springs are installed!!
March 17, 2013 08:06AM
How close does the control arm get to the knuckle at full droop?
March 17, 2013 12:18PM
ill have to measure. the older balljoints had more play in them and would farther...
whats your thoughts?
March 17, 2013 05:19PM
Just wondering aloud. Mine almost touch, and this is also about the point where the ball joint runs out of motion.
March 19, 2013 09:31AM
well i have a fair bit of space, but i think that has to the do with the location of the ears? The ball joints are at a pretty seriously angle though. when they wear in, the car will get more travel. the old ones had about another 5 to 10 degrees in them.
March 24, 2013 11:36PM
March 26, 2013 10:41PM
you're an idiot. Albeit an idiot with a running rally car. Hows the laptop working?
March 27, 2013 02:46AM
didnt work at all for me. kept locking up when talking to my car.... had to work it manually thus far... : (
April 01, 2013 11:49AM
post tune driving this weekend. Going to start body work this week. maybe paint this weekend.
April 01, 2013 12:33PM
Needs more rear tire...
April 01, 2013 12:45PM
Something like this?
http://up.craigslist.org/cto/3713241504.html
Just happened to come across that on the local craigslist today.
April 01, 2013 01:23PM
Redefining "heavy sweep", coming to a rally near you!
April 06, 2013 12:41AM
well..... fuck
so i guess every wonky swap needs its problems. Mine turns out to be that i need to shorten the driveshaft...
The car was occasionally making a rattle / grinding noise. So i went underneath to take a look. The shroud thing was lightly grinding at the tail housing because the driveshaft is too long and slides all the way it possibly can. This also mean i had to pry rather hard to get the shaft off the pinion flange and its doesnt really like going back on... (crap!)
Since the diff was already leaking oil in a nice circle, and I was discussing doing a four link with another axle, I think this is the cue that it is time to make that happen.
eyesoreracing
Dave Coleman
Mazda3, SE-R Spec-V, 510
April 06, 2013 10:05AM
Just make those links a little longer to push the diff back and solve your driveshaft problem...
