Re: Revamping the Rx7
April 11, 2013 09:46AM
50 dollar paint job is done! going to add orange vinyl between the green and white (lemans tribute)
Doug Heredos
Doug Heredos
April 11, 2013 11:25AM
Looks great, Alex!
Doug
April 12, 2013 12:06AM
mostly reassembled
April 14, 2013 01:02PM
eyesoreracing
Just make those links a little longer to push the diff back and solve your driveshaft problem...
Or move the engine a little forward, which is probably why it's bottoming out in the first place.
April 14, 2013 07:29PM
eyesoreracing
not an option unfortunately
April 14, 2013 10:53PM
July 07, 2013 02:38PM
so i am going to have to address the engine. As far as i can tell, from the running hot symptoms to the 2 qts of oil burned in 1000 miles, (normal is almost no consumption at 3000mi) is meaning that the engine has run its course. So it was already suffering when i picked it up.
So that means i need to either
1) rebuild this engine.
2) choose another engine.
frankly, id rather choose another engine. Either go back to a rotary of whatever sort, OR another 4 cylinder piston engine.
Robert Culbertson
Out of this dumpster fire
July 07, 2013 10:33PM
Can't you get a mazda engine through their motorsports program? I know you have to sign up, but you can get an mx-5 engine for $3k new.
July 07, 2013 11:03PM
I would think you could throw rings, bearings, and a gasket set at it for under $500.
Robert Culbertson
July 08, 2013 12:44AM
You could also just throw rings and a gasket kit at it.
Though if you have to run oversized pistons it's probably going to be $500 for a set, and then a head rebuild.
Miata engine correct?
July 08, 2013 08:01AM
correct. It is the 1.6L B6 engine. But there is a 1.8L on CL locally for 100 bucks. Might aquire that and rebuild it instead.
Edited 1 time(s). Last edit at 07/08/2013 08:41AM by Gravity Fed.
jrally
Jon Rood
'94 Escort GT (sold)
July 08, 2013 10:21AM
The 1.8L (BP) engine makes a decent amount of power over the 1.6L. Plus, there are a LOT of know and popular upgrade paths for it. Just make sure to have the correct oil pick-up and pan for rwd, the fwd configuration stuff will cause oil problems. I had my race BP engine, in my Escort rally car, making about 150hp at the crank on pump gas. Although I put a good bit of money into building it, it can still be done fairly inexpensively too, mix and match the right Mazda parts. The one thing I wish I had done was find the '99-'00 head with the shim on bucket lifters.
-Jon
July 08, 2013 11:33AM
Drive it til she blows!!! Then swap in the rebuilt 1.8L.
Done a compression test or leakdown test yet?
July 08, 2013 12:29PM
well she has to get herself to CA under her own power!
havent been able to test anything to do the holiday weekend.
jrally
Jon Rood
July 08, 2013 03:58PM
My first rally car, I had the BP running on a mechanical/vacuum distributor and MegaSquirtII. So the swap can be done easily enough with the current set-up you have, I'm sure.
-Jon
