Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Re: What did you do on the rally car today?
June 19, 2007 08:43AM
Oooh, I finally got out into the garage this weekend.
Finished the following.
- Tack welded the rear wheel studs to the hubs so they will stop backing out.
- Welded a new captive nut in place for the lower rear strut mount on the drivers passenger side.
- Switched back to the gravel springs in the rear.
- Removed the airbag LED from the gauge cluster, just say no to idiot lights.
- Also removed the check engine light from the cluster. This is my work around for the EVAP emissions system issues.
vbares
Vittorio Bares
Audi 4k (3b conversion)
June 24, 2007 08:40AM
Well - tranny is all good and well. Found out that the replacement tranny had been bashed and slightly deformed the casing. The flywheel teeth were blocked as they were dug into the casing.
We cut a piece of the casing out - and voila - all good.
Lesson: Never...pull the tranny in with bolts - it should mate up just pushing it in.
Now, no boost sad smiley only 5/6 psi.
Found the restrictor was in sideways yawning smiley - took that out and we're getting a full 15 psi of boost smiling smiley Who needs no stinkin' restrictors anywayz?
DR1665
Brian Driggs
Keyboard. Deal with it.
June 26, 2007 12:55AM
I looked at it. Put some 89 tail lights on it. Patched some cracks in the radiator with Quick Steel. Considering covering the entire assembly with Quick Steel.
Oh yeah. Got a new job which looks to pay me enough to actually get started. tongue sticking out smiley
owdlvr
Dave Hord
Audi 90q project car
June 27, 2007 11:29PM
I got up at 6:30 and fought traffic down to the wrecking yards in surrey.
Checked up on the new power plant for the rallycar, a 20-valve 5-cylinder. I got lucky, and its' an early build so it comes with the factory stainless-steel tubular header.
It took us three hours to remove the ECU, engine harness and accessories (lights, alternator, radiator fan, etc) harness.
After getting it home and hanging it on the hoist...I spent two hours cleaning power-steering fluid and dirt off the left-side of the engine. Ugh.
-Dave
I'm not scared of commitment...I'm scared of you.
dtompsett
Doug Tompsett
'84 Scirocco Rally car... '88 90q project
June 28, 2007 07:33AM
I take it, from the lack of a 2nd phone call, that you got the heater core and blower assembly out ok?
vbares
Vittorio Bares
June 28, 2007 09:08AM
Nice - sounds like an S2 rally car coming on?
dtompsett
Doug Tompsett
June 28, 2007 09:42AM
similar... except no turbo on this one. 7A 20v engine.
Dave's got more info posted... http://www.motorgeek.com/phpBB2/viewtopic.php?t=1825#195068&sid=c486070898abaa9178d1f873fd159ed1
vbares
Vittorio Bares
June 29, 2007 12:57PM
I remember reading through this thread a while back. Nice details on the car! Whew, you've been at it quite a while - keep thumpin it - you're almost there smiling smiley
What's the first event for the car going to be?
June 30, 2007 12:27AM
Got the restrictor back from the machinist and drilled some holes to seal it. mmmmmm brand new VF34. Gently prodded my man to tidy up the wiring under the dash, figure out the wiring for the remote starter and plumb in some guages. I go to vancouver this week. then I come back, we button it up and start tuning the new motor. 2.something L, 9:1 comp with 25psi. This thing may actually rock hard.
Rally does not suck today.
owdlvr
Dave Hord
June 30, 2007 06:35PM
"Whew, you've been at it quite a while - keep thumpin it - you're almost there "
Lol, yeah. I pulled the car into strip it down and do the motor swap right about the time I cut my income by 2/3rds. Hmmm...those two haven't made a good combination! tongue sticking out smiley
No worries though, the income is back up and the motivation returned about a month ago. She'll be running before too long.
At this point, the whole cage is out-of-date enough that it needs to pulled and redone. Based on finances the car is destined to be my track toy, rallyx toy and navex beast for a while longer yet.
-Dave
gilbrock
Eli Gilbert
91 Galant, 02 WRX
July 02, 2007 01:21PM
I replaced a brake line and bled the brakes. Washed the rally car, removed some gay decals, and took it for a little spin. Will be rewiring the lights and other fun stuff next weekend, after we run the 24 Hours of Lemons race this weekend.
Eli
Rallyho
Mike White
Saab 900 - aka-The Swedish Rally Tractor
July 02, 2007 03:54PM
Well, over the weekend I finished the fuel tank skidpan, got the car down off the rotiseri and fabbed the seat bracket assembly. Don't sound like much but it is nice to have the car back at a workable height!
She's screamn' fer eet!
Rallyho
Mike White
http://www.facebook.com/rallyhomotorsports
July 02, 2007 08:51PM
But how will people know now?
Oh sorry, I hope I haven't outed you!
and
> Eli
> L2 Over Your Mom
vbares
Vittorio Bares
July 03, 2007 09:40AM
Ok - 2 front sooper bitchin suspenders are in - now I need to set alignment and toe.
This required some cuttin' and filing - but it looks pretty good.
Will install the rear suspenders tonight as well.
gilbrock
Eli Gilbert
91 Galant, 02 WRX
July 03, 2007 11:32AM
> decals,
> Wow, that was a good one. Where's the 'rolls eyes' icon
