Re: What did you do on the rally car today?
September 28, 2006 04:03AM
Uh-oh. Sarcasm meter...going...crazy...
Dammit. The needle bent. Now I'll never be able to detect sarcasm properly.
Picked up the head+cams from the shop doing the porting. Cams are matched to the new flow and designed for torque. Hope it works out. We'll see.
Picked up the rebuilt transmission. The Gripper didn't fit right so I went with a Quaiffe. This kinda sucks. I'm not a fan of Torsen-types for rally. We'll run with this for awhile and see how it goes, but I'm looking at a KAAZ for the next gearbox rebuild. One way or the other, I should be able to give a detailed report on a VW Motorsports clutch-type vs Quaiffe Torsen-type in the next couple of months.
This weekend I'll be putting the engine back together. Mmmm...2.1l 16v instead of my old 1.8l 8v. So long Production, hello Group 2.
MRWmotorsports
Martin Walter
Nissan 240SX
September 28, 2006 09:01AM
PAddy Wrote:
> MRWmotorsports Wrote:
> > 17 days to test day...
> And where will this be???
First test will be at the new Calabogie race track, MCO has rented it for the 14/15 Oct weekend. My goal will be to make sure the drive train brakes etc. are all working right, and reliable. The upside to this is I don't have to get all the rally specific stuff (sump guard etc.) done until after. Also don't have to have it street legal, certified, e-tested, insured, logbooked.
I hope to do some stage testing too, once all the rally stuff is done, a co-worker has 300+ acres with logging roads that he'll supposedly let me use.
-Martin.
September 28, 2006 05:25PM
What about it didn't fit? I'd been hoping to save my pennies and get a Gripper.
September 28, 2006 06:23PM
When you put the case together, there's a shim on the bottom, and then you do some calculating to figure out what to shim the top. With the bottom shim in place and NO top shim, the diff was wedged solid when the case was closed. We could've taken out the the bottom shim and shimmed it on the top only (this is what Tom @ Gripper suggested), but that would've thrown the center off.
I'll probably end up taking the diff apart and take some measurements and compare it to a stock diff and see if I can figure out what the dealio is, but I don't really have the time to do that right now so we tossed the Quaiffe in. We'll see.
September 28, 2006 09:13PM
Duuuuuuude, you need to get a couple of inner stubbie axle thingies including the flanges.
On one, weld a big herking nut, like a 32mm or whatever.
The other weld something like a bar so you can bite the bar in the jaws of a vise.
Now screw the diff down and maybe even put the ring gear on if the diff has a split ring gear flage, that is to say if the diff loads the bits on that end and its split (like a Ford Escort or Saab 96 diff)
Now grab your torque wrench and start winding and pulling, and note when the diff turns before the wrench clicks.
Then report.
This clear?
Some initial preload, the diff "locked solid" UNTIL say 90-135 ft/lbs torque applied isn't bad.
And very small changes in shimming can change the preload by shitloads, and no big deal at 020 or 030 diff side to side in the shimming.
And yes I'm familiar with the Gripper diffs, smae stuff as ever but a little nicer.
September 28, 2006 10:40PM
Gotcha. Well, all except the part about the split ring-gear flange. This one's solid and I'm not sure what the split one's supposed to do.
I have another junk gearbox here (8v longbox) that I can cannibalize for parts for the preload tester. The biggest problem is that I'm sort of tight on time for the next couple of months, so I may not get around to it until mid-Nov or so.
September 29, 2006 11:45AM
All that means is, the same bolts that hold the ring gear to the diff, are the bolts that hold the halves of the diff case together. My Maz-dog is like that.
September 30, 2006 10:09AM
Aircraft remover rocks! Eats up my shitty paint like nothing. Got the hood done last night, we'll see how much more of the fumes I can take today.
sagsert
Mustafa Samli
Gaylant VR4
September 30, 2006 11:35AM
Removed rear subframe bushings and instaled the alloy ones.
Fixed the lose wires making the map lights flicker.
Welded plates under rear lower control arms.
Tightened the rear end bolts that were coming lose.
Charged the battery.
Unbent the big ass gouge on the sumpguard.
Ziptied the flashlight pouch.
Replaced the Peltor, not due to malfunction, I have been using the same one since 1983, I retired it out of respect. New one has audio out.
Dicked with the camera and recorder, still no audio.
Got done at 3:30 AM
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
EVO III GSR (Stolen)
Rallies are no place for traitors
Rally West
Rem Wyatt
1985 Golf
September 30, 2006 04:45PM
Installed surge tank/collector in the cell and tested. Washed car cover. Laid under car and looked at it...Grant I know you know what I am talking about here. Found a new radiator leak. Unable to find coolant leak around heater lines. Thought about moving seat back 2 inches.
Gave up and loaded dirtbike in van for a ride Sunday morning.
Thanks To: Billygoat Racing "Smokin' since 1977"
September 30, 2006 09:35PM
Removed some aircraft from my drivers door. Sanded, primered, sanded, bondo'd sanded hood. Bodywork sucks.
mack73
Jason Wine
September 30, 2006 10:37PM
its another weekend so more work on the car.
Stripped the firewall/strut mounts of goo/junk. Tore out the old fuel lines and primered the engine bay
-Jason
Edited 1 time(s). Last edit at 09/30/2006 10:37PM by mack73.
October 01, 2006 01:39AM
d the> engine bay
Stitch welded the fuck outa everything already?
> 94 Golf
> www.Mack73.com
> Edited 1 times. Last edit at Oct 1, 2006 by
> mack73.
mack73
Jason Wine
October 01, 2006 01:11PM
> goo/junk.
> d the> engine bay
> > 94 Golf
> > www.Mack73.com
> > mack73.
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
Not quite yet, just cleaned them all up and put some primer over the bare metal to protect it until stitch welding - that will start in a couple weeks -
-Jason
October 01, 2006 05:54PM
I went to start pulling the suspension apart and broke my foot trying to take the lug nuts off. How lame is that?
